Question about Sony 8GB Micro Drive (SUD8G) -24419 USB 2.0 Hard Drive
My pen drive isn't working. computer shows message ( insert disk into drive H ) when i click on icon of pen drive
Crankstart
  • 696 Answers
SOURCE: "insert a disk into drive" even when pen drive is attached!
Sounds like a failed circuit either in the USB adapter or in the drive itself. You will most likely require the help of a pro with this one if you need to get your files back.
If there's nothing crucial on it, recycle it and grab a new one, if there is important data on it, reply back with your Country, Sate, City and I will refer you to a nearby Pro.
Chris
Posted on Jul 18, 2009
  • 24 Answers
SOURCE: getting message "pls insert disk in drive" on inserting the USB
Hello sir/Madam,
You can recover by doing the following:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
andthen also if you dont get ur full data,you can download Pen driverecovery from many sites(search on google) and recover or else email meat devgolani@gmail.com for full software..
Regards
Devesh Golani
devgolani@gmail.com
http://www.lifeproblems.uni.cc/blogs
Posted on Aug 29, 2009
  • 15 Answers
SOURCE: pen drive problem
when you connect your pen drive then he gave you pen drive symbol on your pc? if he give the symbol then try to open it explolar .if that also it not open then format pen drive.
Posted on Mar 31, 2010
bronk50
  • 27725 Answers
SOURCE: when a king stone pen
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts hope this helps
Posted on Aug 13, 2011
bronk50
  • 27725 Answers
SOURCE: fail please inset disk into
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
example on how to safe photo's or data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps
Posted on Aug 22, 2011
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
Computer shows the pen drive without its name. But when I try to open it gives message 'insert disk in drive F'. I started my computer keeping pen drive attached to it, in tis case, the message is ' format...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 01, 2010 | Kingston 4GB Secure Digital High Capacity...
My 2gb pendrive not working it is not detected
Trouble:
You may have faced a problem when you insert your pen drive and it gets detected very easily but it doesn’t show up as a drive icon in My Computer. The Computer detects the pen drive but data on pen drive is not visible as the pen drive is not visible in My Computer (Explorer).
This problem occurs mainly when windows XP fails to allocate a drive letter to your portable drive(pen drive). It occurs mostly with new pen drives connected to your computer for the first time. If you face such problem then it may not be the pen drive’s fault, rather it may be windows trouble.
If Problem Fix:
Fix:
You can fix this issue by following some simple steps given below.
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. In the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
Jan 29, 2010 | Transcend T.sonic 612 MP3 Player
Pen drive showing insert disk
check your pend drive on some other system if the message is the same, it has become corrupt,replace it
Sep 16, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Pen drive not opening or formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jul 10, 2009 | Pen Drive IVO MP3 Player
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
PEN Drive error
right click on my computer after inserting the pen drive in usb, click on manage and select disk managment from left pan, you can format your pen drive by right clicking on it
Oct 24, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Sony 8GB Micro Drive (SUD8G) -24419 USB 2.0 Hard Drive Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
