Question about Canon ZR100 Mini DV Digital Camcorder
Tape won't insert
Put a tape into the carrier and it just beeps. if you take the tape out the carrier will go into place
Take off battery, set date and time, bang on non carrier side 3 or four times w/ screen closed, voila! worked for me too!
Posted on Jun 10, 2008
Taking off the battery and banging the side worked for me too ... thanks!
Posted on Jun 12, 2008
MY X6170 PRINTER LEXMARK WILL NOT PRINT AND WILL NOT ACCEPT CARTRIGES
Try to open the printer cover and remove the cartridges. Check the cartridge area and make sure there are no obstructions along the cartridge carrier's path. Check the encoder strip (transparent tape) found behind the cartridge carrier along with the carrier belt and make sure it's still in its position and dislodged from its place.
If all is well inside the printer, remove the power adapter (black box behind the printer where the power cord is plugged in) and re-plug after 30 seconds. When the printer turns on, re-insert the cartridges.
Try to print again to verify that the problem is fixed.
I hope this helps.
Jan 26, 2012 | Lexmark X6170 All-In-One InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
How to change the ink cartridge?
Download manual from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
Dec 31, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Where do I put the replacement cartridges?? I can't see where it goes on this printer???
here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
MANUAL:
Open the printer, and then press down on the print cartridge carrier levers.
Open the color cartridge foil, and then remove the cartridge from the pack.
Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
cartridge lid.
If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
Note: You may need to purchase a black print cartridge separately.
14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
the cartridge carrier lid.
Close the printer, and then load plain paper
Mar 26, 2010 | Lexmark X4650 InkJet Printer
I have a Canon Elura 65 mini DV camcorder. When I
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
Dec 19, 2009 | Canon Elura 65 Mini DV Digital Camcorder
When turned on - a beep is all i get-keys won,t work at all. 7040 swintec typewriter
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
May 19, 2009 | Swintec 7040 Typewriter
Canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Mar 27, 2009 | Canon ES900 Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
