I HAVE LG WF-583SPC FULLY AUTO WASHING M/C AND MAIN CONTROL PCB IS DEAD IN M/C. WHERE SHOULD I GET/REPAIR THIS PCB? WHAT WILL BE EXPECTED COST OF THIS PCB?
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
  • 713 Answers
SOURCE: My LG Washing Machine WF-T853A is putting black ru...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
Posted on May 15, 2010
  • 5128 Answers
SOURCE: where does the fabric softener
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Posted on Feb 13, 2011
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
The SE light flashes when turning on the washing machine
Not sure which washing machine you have. But assuming it is an LG SE is a serious fault.
Motor fault detected Can also be caused by be main PCB
This is not a good fault code to see as it will generally be correct and either the washing machine drive motor or the main electronic control PCB is faulty.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
For more detailed analysis please post make and model of your washing machine in the comments field.
Sep 26, 2014 | Washing Machines
PE error for LG Washing machine WF-t7269 KN. Cleaned the water filter still shows error.
LG's 'PE' does indeed stand for (water) Pressure Error'
(following is pre-typed!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 25, 2011 | Washing Machines
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Feb 03, 2011 | LG Washing Machines
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Sep 16, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
