Question about Dishwashers
Water is not coming into the machine despite making the sounds that the machine is trying to proceed with the cycle?
    Problem Solver:
  • 12 Answers
First make sure water to machine is on.
Second There is a filter screen between the inlt hose and valve. It is clogged remove clean and replace.
Third If this does not solve problem then replace valve..
Posted on Aug 25, 2010
Indesit idf 125 freestanding dishwasher. In all programmes dishwasher goes through wash cycle, but doesn't proceed into drying mode, instead it starts wash cycle again.
Is it a model with a mechanical wash timer, or electronic control? Either way, sounds like the machine is not acknowledging the program end condition, and may need replacing
Feb 02, 2018 | Dishwashers
Machine stopped on the rinse cycle with the display showing "caution high water level", I tried to cancel the program and the display shows "cancelling program" and sound like it's proceeding but it...
Unplug your machine and start a new load. The machine will since that there is enough water in the machine and finish the cycle. If you are still having problems, call the manufacture's phone number listed in your user guide or their web site. They usually have contact information listed. Also, check the troubleshooting guide in your user's manual. You can probably download one from the internet.
Dec 10, 2013 | Dyson Washing Machines
Washer will not proceed to rinse cycle
Maytag leaks This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 14, 2013 | Maytag Neptune Washing Machines
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
Water wont come out and making loud noise
Either you have a bad inlet water valve or the control board and timer are not communicating correctly to allow water to enter and proceed to the new cycle. Contact a professional for a full diagnosis before you go further.
Aug 31, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
The machine says "ready"
That Sounds like theres a blockage, most likely limescale has built up in the boiler. If you try descale now when water is only dribbling through, it probably wont work. Recommend strip down machine and unblock pipework and try get water flow to come back stronger, then try a descale cycle.
Mar 29, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Water not draining
It must have drained water out at some stage because it got to the end of the cycle.It sounds as though the pump may be blocked.The pump can be gotten to by removeing the rear panel on the back of the machine,make sure the machine is unplugged.water will come out so first try syphoning the water out of the machine.if the drain hose comes out from the bottom of the machine then just lay it down into a bucket to get the water out.
Jun 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dishwashers Logo
18 people viewed this question
Top Dishwashers Experts
