Question about Microsoft Visual Studio 2005 Standard Edition for PC
Can i installed 32 bit applications on 64 bit processor?
    Novelist:
  • 101 Answers
The answer to your question above is Yes, you can install 32-bit applications on a 64-bit desktop/laptop. Please note 3 things:
1. The 64-bit environment will be determined by both the CPU and OS being 64-bit capable. If one of the them is not, then the system will not perform at the 64-bit level.
2. 32-bit applications can be installed on a 64-bit OS and they will function properly - but only at a 32-bit level. They will not take advantage of the 64-bit environment until the application is certified for 64-bit.
3. 64-bit applications cannot be installed on a 32-bit environment - they won't run at all.
Posted on Aug 28, 2010
  • 25 Answers
Yes you can. 32 bit apps can be installed and run in 64 bit environment, but the reverse is not possible.
Posted on May 18, 2014
How it works if I install 32 bit or 64 bit OS in 64 bit Processor PC. Which one will be fast?
The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system.
Jun 14, 2016 | Computers & Internet
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Can you run office 32 bit on a windows 64 bit operating system?
You have 32-bit Office installation package (CD/DVD/file) and 64-bit Windows operating system. Is it correct?
General answer is YES, I can install a 32-bit application on 64-bit OS. I have exactly same situation in my laptop. Both 32-bit LibreOffice and 32-bit MS Office are installed on W7 & W8 laptops and work well.
But NO vice versa. The 32-bit system does not allow to install 64-bit application. The 32b system does not support 64b instruction set required for 64b applications.
My experience is confirmed by many other users:
Office 32 bit to Windows 7 64 bit
Jan 29, 2014 | Microsoft Windows 7 Professional for PC
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
Hello, i have amd athlon 3.0 ghz 2gb system. i want to install windows 7 64 bit. and i llike gaming too.... i have nvidia gforce 9400gt 1gb. 1) so can i add more ram virtually for 64 bit??? 2) will...
if you have windows already installed you can use the upgrade advisor and that will tell you what programs will be affected http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Mar 11, 2011 | Microsoft Windows XP Professional for PC
Compare toshiba processors
not the procesors are 32 or 64 bit they are only support that ,32 bit and 64 bit are the O.S. ,so you can instal a version with 32 bit or 64 bit.;most procesors especialy dual core supports them both.
Nov 30, 2009 | Computers & Internet
Can i install a 64 bit of 32 bit Computer?
Yes you can, unfortunately you can not upgrade from 32bit to 64bit, you would need to do a fresh installation. Also your processor and motherboard need to support 64-bit architecture. If you start the installation for the 64bit if the architecture isnt supported it would notify you that the installation can not be completed with an error message.
Enjoy your copy of Windows 7 64-bit if it works.
Nov 16, 2009 | Compaq Presario 5000 PC Desktop
I have XP sp3 installed on a Althlon 64 processor but I can not run windows defender 64 as it keeps showing message not supported by processor
You have a 32-bit OS on the computer so you have to run Windows Defender 32-bit regardless that you have a 64-bit processor.
Apr 17, 2009 | Computers & Internet
Microsoft Visual Studio 2005 Standard Edition for PC Logo
482 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
