Question about Kodak EASYSHARE Z1485 IS Digital Camera
Canera lens will not close I have tried 2 different batteries after they have been recharged
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 25, 2010
Lens cover would not close. Now camera will not turn on.
Lens cover not close, This will happens due to two reasons.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
Mar 03, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
The screen is not going on ? its black and when i turn it on only the lens part goes on and when i turn it off its stays the same way ? so wat should i do ?
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Oct 10, 2008 | Cameras
Total power falure
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Lens cover error
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
I have the Nikon Cool Pix 5.0 Megapixel Camera
try rechargeable batteries, don't know why, but they work better than alkalines and are recommended for cameras :)
May 20, 2008 | Nikon COOLPIX L10 Digital Camera
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Lense does not close
sir, ur camera lens mechanically stucked or gears problum ,this is repairable
Apr 12, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Kodak EASYSHARE Z1485 IS Digital Camera Logo
12 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
