Question about Maytag MSD2756GES Side by Side Refrigerator
What causes ice build up on inside freezer coils
  • Maytag Master
  • 1,606 Answers
To check the defrost circuit , unplug the refrig and inside the refrig section at the top
about 2" in from each side in the back , there are "D" slots to put a finger in , and pull
downward and foreword , to remove the control panel cover . Once removed , there is a 1/4"
screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both
light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these
5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive
defrost board ( adc ) . Sometimes you can see the electronic board and on newer refrig's , a
white
box will be seen . Inside this box , is the adaptive defrost control . Disconnect the plug
going to the board and on the right side of the PLUG , the far right wire is yellow , then
another color , then white . Using a small insulated wire with both ends stripped , insert
one end into the yellow wire hole and the other into the white wire hole . This will send
power directly thru the defrost bi-metal ( thermostat ) AND
heater to check if they are good .Plug the refrig back in . Now , if you have a clamp on amp
meter , clamp around the jumper wire while pushing in the light switch ( to turn off the
light to get only defrost amps ) which should be 3.5 or above indicating bi metal and heater
are good and adc is bad , OR , wait about 3-5 min and
look for a red glow at the bottom of the inside freezer panel , which will be the defrost
heater or listen for sizzling which will be the frost melting and dripping onto the heater
.If NO red glow , watch for a spark while removing the jumper wire you installed , from the
plug . If a spark IS seen , then the heater was on and the heater AND bi-metal are good . If
you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost
board should be replaced . If no glow , sizzling or spark , then unplug the refrig and
reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer
panel on and the freezer panel , can be removed . Remove the panel . If the heater (black
element at the bottom of the coils ) wires are visible , trace them to the top of the coils
and disconnect . Use an ohm meter to determine if the element is good ( should show
continuity ) . If the element IS
good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils .
This is the defrost thermostat ( bi-metal ) . Replace this part if the element shows good .
If the element shows bad , replace the element . NOTE 1 : sometimes the element and the
bi-metal come wired together and the replacement part comes with a new heater and bi-metal
already wired together . This would be the advisable replacement part . However , each part
can still be replaced individually . NOTE 2 : If looking at the bi-metal and the top plastic
" cap " looks cockeyed , replace the bi-metal as moisture has gotten inside and disturbed
its
designed function
Posted on Aug 25, 2010
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
Oct 12, 2013 | Refrigerators
Model No IK 458 -4-4T; Product No 925 780 652 02 Ser No 14100010. I get ice build-up on floor of fast freezer comp which jams pull-out basket.
If the defroster coil is not working, then ice will build up on the coils inside the back of the refrigerator.
But, you're saying that it's accumulating on the floor of the freezer jamming the pull out basket.
I would say that the timer or overflow valve is bad on this refrigerator causing ice to build up on the floor of the fast freezer compartment causing the jamming.
Jul 19, 2010 | Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
It seems the fan goes on more than it should. How often should it go on?
Both fans should run when the compressor is running. Dust on the condenser coil under the fridge can cause it to cool less efficient. Ice build up on the evaporator coil inside the freezer behind the rear cover will cause it to be less efficient. Heavy ice on the coil is caused by auto defrost failure.
Jan 18, 2010 | Kenmore 50522 / 50524 Side by Side...
Freezer thermostat stuck on A frost build up in
check the coils underneath and behind the freezer. the back on may be inside on the back wall behind a false panel. If so, disreguard this one. Take a vacuum cleaner and **** as much dust out as you can. This sounds like air flow restriction causing icing on the coils making the freezer go into defrost mode(for the evaporator coil). Also check to see if you hear the fan running when yoiu open the freezer door. It can be replaced if bad
Nov 26, 2009 | Refrigerators
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore Elite ice maker doesn't work
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting.
If it still exists then there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Sep 25, 2009 | Kenmore Refrigerators
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Nov 12, 2008 | Refrigerators
Maytag MSD2756GES Side by Side Refrigerator Logo
114 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
