Question about Sony Ericsson K850i Mobile Phone
My phone won't start up...it just appear led light
  • 277 Answers
WON'T TURN ON
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Posted on Aug 25, 2010
My screen won't lite up
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 21, 2012 | Toshiba Satellite E105-S1402 Notebook
Toshiba won't boot up
May 10, 2012 | Toshiba Satellite U405-S2826 Laptop
Won't display
Apr 13, 2012 | Computers & Internet
Laptop won't start
Mar 14, 2012 | Dell Computers & Internet
I replaced the battery on my remote starter and now it won't work. The lights come on but it won't turn over.
not in backwards (battery) but led should not show as they are polarity dependant, didnt format the remote by accident somehow? any error msg on dash?
Feb 18, 2012 | Directed Dei Valet 561r Remote...
Imac intel will not power on
Possible failed video card. 3rd LED indicates MLB and GPU are communicating: (CAUTION! There is high voltage from the powersupply so any attempt to open iMac other than removing glass panel to see the indicators...should be done by authorized ACMT)
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Aug 01, 2017 | Apple 24" iMac Desktop
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
Sony Ericsson K850i  Mobile Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
