Question about E-Machines eMachines Desktop PC
Start-up will not powerup
  • Anonymous May 05, 2008
    driver audio
  • bowhuner May 08, 2008
    replaced power supply,still won't power up.
  • E-Machines Master
  • 5,568 Answers
If you have already tried disconnecting AC from the wall to force a reset, then your power supply is defunct.
If it is a systme built witnhin the last 10 years by eMachines, it will use a standard format supply.
Bought from a local store, they may try to rip you off since this kind of commodity supply can be had for well under $20US on eBay, less right now - http://cgi.ebay.com/NEW-400W-Power-Supply-fo-BESTEC-ATX-300-12E-eMachine-PC_W0QQitemZ250242542239QQihZ015QQcategoryZ3670QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The pictured supply is 99% likely to be the form factor you need and the supply you currently have is probably less capable than the one offered.
If you choose to do this yourself (it's easy with a little attention) you might want to take a digital photo of cable routing and placement in case you get confused.
Posted on May 05, 2008
Have the power supply replaced. It is a very simple procedure. I would recommend buying an 80+ model which is very efficient.
Philips LX700 fuse blowing on powerup
Philips LX3000D - Fuses blowing on powerup. Help.
Jan 23, 2014 | Philips LX700 System
Powerup problems
you should not leave PC on for more than a couple days.
It may have gone into Hibernate and if there is a bad sector, (i.e. read errors,) when that is loaded into RAM, then that can cause many symptoms. Try to boot into Safe Mode, then if that works, Restart and use Normal mode.
Aug 31, 2012 | E-Machines T6532 PC Desktop
How to powerup the motherbaord without power switch
Hello, you can visit the dell homepage
and enter the sevicetag it should be at the back of your machine:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
The pinout should look like this:
You must use the pwrbtn or power pin to power up the mainboard.
Beware of static Electricity
Hope this will help you.
Aug 14, 2012 | Dell Computers & Internet
Power light is on no status light wont power up tried new bulb.
Did you ever find a solution to the no-powerup? My HC1100 has started doing the same thing.
Apr 11, 2011 | Mitsubishi HC1100 DLP Projector
After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
Hit the + sign until you get to NO MOTION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Sep 20, 2010 | Zebra Stripe S400 Label Printer
Unit will not powerup at all. I plug it in an turn
check to make sure it is full as it is auto shut off and check wire that it was not mulled out when someone tried to move it, also if it has a gfi make sure button is pushed in
Oct 28, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
LP580 not powering up
reset lamp hrs and flash new software.
Nov 06, 2007 | InFocus Office Equipment & Supplies
E-Machines eMachines Desktop PC Logo
88 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
