Question about Frigidaire Refrigerators
It doesn't cold,make no ice,but it's On! I have frigedaire side by side refrigerator.I didn't used since 5months,now i turn On,but it's not cold at all. Thanks,,
    President:
  • 2,559 Answers
Make sure the temp setting is set to the temp that you want,and allow 24 hours for it to reach that temp, if it still is not cooling, then you have one of a few different problems, 1 the start capacitor is bad, 2 the control board is bad, or 3 the compressor is bad..
Posted on Aug 25, 2010
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
Door seal on my Frigedaire sise by side gets hot, what is wrong?
I had this once with a Fridigare GLRS267ZAQ4 side by side but it was also heating up water and the freezer wasn't working very well.
My problem was that the coils and condenser in the back bottom of this unit needed a major cleaning and the fan wasn't working very well. Cheap to buy that part and replace yourself. This problem was causing this unit to heat up everywhere because the coils and compressor were not being cooled properly.
I have often found this unit to get ice build up in the back inside wall and had to take a hair dryer to it in order to melt the ice. This mostly caused problems with the ice dispenser and freezer getting warm.
Right now I am having a problem with my refrigerator not cooling well but the freezer is fine. Guess I'll try to defrost the ice and check the coils again.
Hope this helps!
Kyle
Dec 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigedaire icemaker problem. Water line, maybe.
Did you turn the water back on? Pull the live off the back of the fridge, put it in a bucket and have someone hold it. Then go open your water valve for about 10 seconds. That will at least tell you if water is getting TO the fridge.
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer keeps buzzing
don't worry! its the sound of compressor vibration and it is normal........if the sound is more than turn round the refrigerator and tight the nuts of the compressor stand......................have a nice day:-)
May 14, 2009 | Samsung RB2155SH Bottom Freezer...
Icemaker has to be manually turned off
frigidaire has 2 diff i/m units if you have the one that has the i/m along the left hand wall of the freezer then probably you have a broken shutoff cam in the ice maker. solution is replace the i/m
if you have teh model with the icemaker along the back wall. over production of ice is nature of the beast and not really anything you can do about it.
i know neither is solution is great but i hope it helps peyton
Jan 18, 2009 | Kenmore 73503 Stainless Steel Bottom...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
14 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
