Question about Dell E172FP 17" LCD Flat Panel Monitor
Hello, My DELL E172FP suddentlty goes down, the power switch green light flashing. = I opened it, have found a 2SC5707 switching transistor KO = I replaced it = Now the switch green light is still flashing, but the power card is not connected to the screen. Do You think it is normal or is it due to an other problem, before I reassemble the monitor. Excuse me for my poor english (I am french) Thanks in advance for Your answer, Regards, Bernard
    President:
  • 2,559 Answers
This is due to a power supply issue, Check all the power supply solder joints, And try a reset by unhooking the power and holding the power button down for 30 seconds, This allows for a total discharge of the unit, Then plug it back in and see how that worked...
Posted on Aug 25, 2010
Press power on... screen flashes on (blink), then goes blank and power button flashes
dpelrod727, Yes, the "switch-mode-power-supply" is in "partial" or "full" SHUTDOWN mode. Reconnect E172FP to a fully booted KNOWN good PC with the win-desktop as the displayed screen. Check with flashlight to see if your LCD panel is both BLACK and BLANK, or just BLACK by holding a bright flashlight 1" from screen at different angles even though the screen appears to be blank. If very faint image of desktop is seen then your SMPS is still half alive. Here are your options in either case. 1. Trade in for new. 2. Try Dell for a cash+old swapout for a Refurbed unit. 3. Check out www.ccl-la.com/badcaps, www.badcaps.net, www.lcdparts.net, and YOUTUBE long video clips dealing with LCD monitor disassembly and LCD repair. could be helpful in making decision on what to do. I'm 12fixlouie If this was helpful rate on fixya.
Nov 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor displays desktop for a short while
this kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
Aug 17, 2009 | BenQ FP71G 17" LCD Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E152FPc Monitor powers up, and screen goes blank in 5-10 sec
ok every one there is a fix the are 4 transistor 2sc5707 and 2 transistorfu9024n and i cap 16v1000uf
if you replace these your problem will be fix for a while but to it better then dell replace the 2sc57o07 with radio shack tip3055 they are 15 amp trans instead of the low 8 amp dell uses they fail because the amps at the test for the transistor is more than 8amps all the correct parts are sold in a kit on ebay look up the 2sc5707 but i recommend upgrading to the tip3055 transistors they are a bigger transistor but you can lay them down and they work great. the capicator can be found at radio 35v1000uf is a good replacment make you monitor better because the new parts are stronger then the originals so no more failures after.
Jan 26, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP, monitor blinks then goes blank or black
This is a known problem of the Invertor board.If you are technically able you can open the monitor and resolder transistors 2sc5707 as also all pins of 4 yellow invertor transistors that you can see near the backlight connectors.
Samir.
Please rate the solution and provide feedback
Sep 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Display dies 3 seconds aafter Power on
http://josepino.com/other_projects/?howto-repair-dell.jpc
This is one soution, many more on the net.
You got parts to fix inside the monitor. Inverter problems. The internet is full of this problem. Some say that even if you replace the bad parts, mostly 2sc5707 transistors, you must find out why they are blowing. Many have replaced the parts only to find out that in a couple hours, the parts are bad again. Solutions range from solder joints, transformers, and other transistors.
Good luck, I'm fixing one as soon as the parts arrive.
Gary
Aug 17, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Blinking Power Light
Just wanted to say Thank You for the info on this site. I had the same problem as previously posted. When powered up, the monitor showed a fast flash of the desktop and then went black, with the power indicator flashing green. I read the posts, purchased the capacitors and the 4 - 2sc5707 transistors through ebay. I ordered them on the 6th and rec'd them today. I only had one bad capacitor and one transistor that checked bad, but I ordered 5 caps and 4 transistors. When ordering the caps be careful of the height of the caps. I found this to be a problem because I ordered the 50v, 105 degree Panasonic caps that didn't fit with the enclosure attached, so I used the 4 good caps removed previously and replaced the bad one with a 470uf, 50v. 85 degree cap from Rubycon I found among my spare parts. Installed the parts and the monitor is working properly (for the last two hours) so I'm happy for as long as the repair lasts. Thanks again for the info.
Dec 05, 2006 | Dell E173FP 17" LCD Monitor
Flat Screen trouble
you need to replace switching transistor 2SC5707 in the Power Inverter Board.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
Oct 03, 2006 | Dell E173FPb 17" TFT LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
91 people viewed this question
Alun Cox
