Question about Cobra 148 GTL 120-Channels Base CB Radio
Indicator light doesnt work and the meter doesnt work.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
If your TX (Transmit) meter does not work at all, it might or might not be a faulty press-to-talk switch, or faulty wiring. More often, it's the final amplifier stage that's defective if you don't have a carrier (signal) when you key the mike. That will require a qualified Tech to make those repairs. I'm basing this on my experience as a Communications Technician since my Navy days and CB Dealer since the mid 1970s. Thanks
Posted on Sep 01, 2010
Left rear turn signal, rear hazard lights not working
You will be needing a good electric meter.
With the key on and the turn signal activated, test the leads inside the light socket and see if electricity is getting to the bulb.
When you mentioned it flashes really fast, that says one of the bulbs is not working.
Although it could be burned out, it could also not be making contact, or the ground wire could be bad.
Since the early '80's, cars and trucks have had separate ground wires to each and every bulb and electrical component, and a bad ground will cause this problem also.
Remember, a bulb can look good and still be no good.
God bless your efforts.
Apr 19, 2016 | 2007 Ford Freestyle Limited
Bajaj Pulsar 150cc Dtsi right side indicator working but showing inactive in the meter guage panel, left side indicator is not working but showing active in the meter guage panel. pls sugges me what to...
Hi, I would check the bulb[s] on the side that doesn't work. You may find the relay that switches the indicators needs all bulbs to be good to operate correctly. If you get all the indicators to work and the meter panel still shows inactive (I assume you mean the warning light does not work) then check the light in the meter panel.
Jan 29, 2014 | Bajaj Pulsar 150 Motorcycles
Brand new cobra 29ltd second 1 same issue so i ruled out an internal issue, every thing works cept no sound and my channel indicator doesnt light up
Make sure your not using. the 24volt in the newer trucks. use a volt meter to double check for 12volts + and -..
it probably blew a capacitor common problem its a low voltage style. near the channel selector.
Oct 17, 2013 | Radio Communications
Relay starter
sounds like you have a short somewhere
Aug 24, 2013 | 2009 Bajaj XCD 125 DTSSi
Battery charger light doesnt work showing that the batteries are being charged.
okay first of all check that the batteries can be seen from the charger socket, otherwords get a electronic meter and insert the probes in the two outside holes , do you get a reading on DC ?
Nov 29, 2012 | Pride Mobility Jazzy Select Wheelchair -...
Back light and meter light dos not work
please explain what meter light is ?? i suspect that you mean the indicators and if none work then its bad earth or ground connection
Apr 15, 2012 | 1995 Kia Sephia
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
Hello, the front left indicator is not working neither flashing at all. The rear left indicator just stays lit and does not flash. The right indicators work fine. I have bought the correct bulbs and...
Concentrate on the front indicator.
With a meter check you have an intermittent supply with the ignition on and left indicator selected.
If its ok, it will be an earth (ground) problem. Check using a temporary earth wire from the indicator unit to the chassis.
If no voltage found at indicator bulb, trace the supply cable back to source.
Sep 23, 2017 | 2007 Yamaha Ybr 125
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
O2 Dodge Dakota Brake lights wont work but bulbs r good.
If the bulbs are good I would suspect the Brake light switch.
Brake Light Switch: Testing and Inspection
The brake lamp switch can be tested with an ohmmeter. The ohmmeter is used to check continuity between the pin terminals.
Switch Circuit Identification
- Terminals 1 and 2: brake lamp circuit
- Terminals 3 and 4: RWAL/ABS module and Powertrain Control Module (PCM) circuit
- Terminals 5 and 6: speed control circuit
Switch Continuity Test
NOTE: Disconnect switch harness before testing switch continuity.
With switch plunger extended, attach test leads to pins 1 and 2. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 3 and 4. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 5 and 6. Replace switch if meter indicates no continuity.
Sep 11, 2009 | 2002 Dodge Dakota Club Cab
Cobra 148 GTL 120-Channels Base CB Radio Logo
43 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
