Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
On refrig both temp says -47 and its clicking coming from back of refrig
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
Refrigerator
Unplug it for 2 minutes to do a hard reset. If it does not reset check the temperatures with a thermometer if the temps are off by more than 5 degrees your temp sensors are out of range
Jul 25, 2013 | Refrigerators
The temperature reading on the outside door panel flucuates
Could be a fan problem, open the door and hold the door switch in, the fan should start and you should be able to feel air coming out the vents (air flow is not very strong as it comes out many vents so you will feel a cold breeze rather than a strong air flow if it is normal. Also check if you can see any ice nuild up in the back of the freezer as it may be a defrost problem and the air can't flow due to the ice build up, if this the case it will need to be looked at.
Apr 18, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have a GE referigerator Model # GSH25KGRE of 4 years old... I hear a constant click-click noise coming from the back/motor..and I suspect the temp in the freezer is slowly dying down..
The clicking behind the refrig , is comming from the main control board , behind the 8" X 10 " panel . The part number is WR55X10656 . The compressor relay , on the board has burnt . Yes , your freezer is thawing , due to the clicking .
Sep 23, 2009 | GE Refrigerators
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Why am I not getting any water from door dispenser for model GSS23KGSA BB
Pull refrig out , and remove the back panel . At the water valve (piece the wall water line connects to , push up on the white ring and pull the LARGER line from the valve . Activate the water dispensor and see if water comes out of the valve . If no water , replace the complete water valve . If water comes out , reinstall the hose by pushing back into valve , and remount valve and rear panel . Push refrig back into place . Remove the bottom kick plate and disconnect the water line about 6" under front , from the coupling (pushing in the ring and pulling hose ). Press for water again . If no water comes out , probably frozen resevoir behind the refrig crispers , so turn refrig temp slightly warmer for a few days , to unthaw (or use hairdryer) . If water shoots out from hose , then water line inside door is frozen . This would be a more difficult procedure to follow . You can try adjusting freezer temp slightly warmer for a few days to see if it will thaw . If it doesn't thaw , come back to this thread with " water in door frozen " and myself or another expert will be glad to help you .
Sep 09, 2009 | Refrigerators
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
Temperatures fluctuating
Wonder why the "repair men" can't find a defective temperature control or circuit board.
Nov 06, 2017 | Frigidaire Refrigerators
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
12 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
