Question about Acer AL1912 19" LCD Monitor
I have hooked my Acer 1912 monitor up to my toshiba laptop as a second screen. When I select a resolution of 1280 x 1024, the display on the monitor slides over five inches to the right and I only see half of the display and the left half of my screen is pitch black
  • 2,973 Answers
Friend,
On the monitor go to settings and shift the screen to the left till the display is correct. However, please check for other resolutions after you have shifted. May be the monitor is not geared up to take on 1280 X 1024. Check that as well.
Posted on Aug 25, 2010
  • jtehini Aug 25, 2010
    I had tried that. the display moves over an inch, but that means around three inches of display are still hidden from me. I also looked at the specs and the monitor is meant to take 1280 x 1024. What confuses me further is that no matter what resolution I choose, it is either to fuzzy to read or does not display on the screen completely.
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
How do u connect a ei53fp monitor to a 1336 by 768 reolution laptop
Attaching a second monitor to a Laptop, if its fairly new, will automatically load a second display. Right click the background on your LAPTOP screen and select properties after you attach the monitor cable. Go to settings. You should see two monitors. If not, you need to press Fn+ F6 on most Laptops to activate the second monitor. See your owner's manual on function key (Fn) Choose the second monitor screen and set the desired resolution.
Apr 17, 2010 | Dell E153FP 15" LCD Monitor
Hook netbook to tv with rca cables
after hooking it the TV we need to toogle to the external monitor.
Presentation or mirrored display mode
  1. Right-click an empty space on the desktop, and select Personalize .
  2. Select Display Settings
  3. When the New Display Detected dialog box appears, the images on both of the displays will be automatically mirrored.
  4. (Optional) To adjust the resolution, so that the display area of the monitors are the same size in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
The computer is now ready to display the same screen on all output devices, from monitors to projectors. Press the fn and f4 function keys at the same time to switch the image from the notebook display, to the external monitor, or to both. Extending the desktop
  3. Select the monitor representing your second display. Click the Extend the desktop onto this monitor checkbox and click OK . NOTE: To help identify your monitors, click Identify Monitors . The numbers 1 or 2 are shown on the monitor icons to help you identify them.
  4. (Optional) To adjust the resolution, in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
  5. (Optional) To change the direction the desktop will extend (left or right to match how the displays are physically set up), select a monitor and drag it to the desired position.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
Dell monitor and acer one laptop
Yes, you can connect. BUT, after that right click on the desktop and select Properties->Settings. There you will find two monitor icons. The left one is your Acer display while the right one is your new Dell Display. Select the right one and configure it. You should have the same resolution and color as the main Acer display to use it optimally.
Aug 09, 2009 | Acer Aspire One PC Notebook
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
My screen is bigger than the monitor for my toshiba satellite laptop.
Hi.
What is happening is the settings that you have set on your laptop are too high for the monitor to recognize.
You will need to reduce the resolution settings in you display properties which can be found by going to start-settings-control panel- display- and in the display area choose settings.
Some video cards will let you adjust each item. Some you have to use the same resolution on both screens.
Shout if you need furthur input !
Fran
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
