Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
I'm trying to clean the brushes under neith and trying to figure out how to take to plastic part off so that i can clean underneith. I think the brushes come out but i'm not sure how.
    President:
  • 1,673 Answers
The brush block wasn't made to take apart and clean. The whole block will come out, it just cames catches that hold it in place.
Posted on May 15, 2008
The brush motor seems to be jammed with hair, I can't figure out how to clean it out. Can it be disassembled and cleaned?
depends onn make and model of vacuum. Most brushes are belt driven and not linked to a motor. For hair around the brush bristles carefully cut along the length of the brush roller taking care not to cut any of the bristles, then pull them off. Some makes have a releasable base to make this easier, these have several large plastic screws that turn with a coin. Hope this helps
Aug 03, 2016 | Vacuums
My brush is not turning and the belt is on the motor. I think the belt motor may be bad due to excessive dog hair. How do I get to the motor?
I had one melt the plastic around the bearings on the brush. you might try taking out the brush first, getting to the motor you'll have to take it completely apart.
Feb 27, 2015 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hello. I took the sole plate of to clean the brushes on my dyson dc14 however the brush part came out and i put it back in but since then whenever i switch it over to carpet setting it makes this really...
You really need to take the sole plate back off and make sure the belt is running exactly where it's supposed to go and not looped over a piece of plastic or anything. More important is that you make sure the ends of the brush are seated properly and the bearings the brush is mounted to are clean and rotate freely. Look at each component and make sure they are assembled perfectly. Make sure a plastic ring or piece that goes on the end of the brush didn't get dropped under a piece of furniture and you forgot about it. If the problem keeps happening, take the brush and belt back out and carefully turn the machine on to see if it makes the sound. If it doesn't make the sound with the brush out, the problem is with the brush assembly. If it does make the sound, the clutch that turn the brush on and off is damaged and needs to be replaced. You can order a new clutch assembly and replace it without much trouble. They want you to think you can switch between floor and carpet settings all the time but it's really really stressful on that clutch to switch between settings with the motor running. Think about how powerful that motor is. Think about the poor unassuming brush assembly being jerked to life by that powerful motor running at full speed. I've seen that destroy a clutch in about two years. Anyway, it's much better for the life of your dyson to turn the motor off when you switch to carpet mode (when you turn the brushes on). You probably don't have to bother turning off the motor when turning the brushes off, or switching to bare floor mode, because it's not that stressful on the mechanism to just disengage the running motor.
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
The brushes on the unit do not spin.
try to clean the filter under the machine or the filter behind the clear plastic, were you see the hypnotic disc sprin that lets you know that the brushes are spinning. To remove : the plastic piece that looks like a triangle, ( were the indicator is that lets you know the brushes are turning ) remove by pulling from top, clean lent from screen and reverse your steps to put back on.
Jul 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes don't turn
I Had the same problem, The brushes are operated by water pressure. Under the machine were the brushes are is a white peice of plastic pull this out and try cleaning the screen. I found this when I removed the cover and lubricated the gears at the brushes, If that does nto work you will have to remove the turbines and lubricate.
Dec 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
