Question about Samsung YP-K3 MP3 Player
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea? every time i plug a usb in to my computer it comes up that this device can perfom faster on a hi-speed usb port
  • Anonymous May 06, 2008
    I too am facing the same problem mentioned above. In addition, some files looks missing, with low speed usb port while it is visible in hi-speed USB port.
    Sergeant:
  • 250 Answers
Hello BILLBOBAGGIN,
Depending on the hardware, your computer and devices may support three different USB data rates:
Low Speed - 1.5 Mbit/s
Full Speed - 12 Mbit/s
Hi-Speed - 480 Mbit/s
It sounds like the USB hub you are using is either a Low or Full Speed hub. The Hi-Speed devices you are plugging in will still work, but the transfer rate of the data will be slower then what the device supports. The error message is just to inform you that you could be getting higher data transfer speeds if your USB hub supported it.
For faster performance I would recommend upgrading to a Hi-Speed USB hub,
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 05, 2008
This is not an error it just means that you are plugging in a usb 2.0 device into a usb 1.0 port. The devise will still function normally just not as fast. You could always add a usb 2.0 pci card to your computer.
  • Anonymous May 05, 2008
    Excellent information Ken. One thing to note, upgrading to a hi speed USB 2.0 hub will not enable USB 2.0 on a computer that does not already have it.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 09, 2010 | A4tech Viewcam PK335 Webcam
Portege 3490CT problem with external CD-RW backpack
This is nothing to be concerned about it the message is just informing you that you are plugging a USB 2.0 device into a USB 1.0 port, which means that it will still work but will run at a slower rate than it would if you had a USB 2.0 port
If you want to turn off this error message follow the instructions here
http://support.microsoft.com/kb/835967
I hope this helps
Jan 20, 2009 | Toshiba Portege 3490CT Notebook
Ipod wont show up on itunes
When you have a high speed device like the ipod plugged into a non high speed usb hub, all that means is that it will take the ipod about twenty times longer to load up under itunes then it will using a high speed port. Try connecting the ipod to a different usb port and see if that one is a high speed port (if it is, it will most likely have 2.0 written beside it, and if it does not have it, when you plug it in, it will tell you if it is a non high speed usb port. The same message should pop up. Try all of the usb ports on your computer. You should have at least 1 high speed port.
Nov 08, 2008 | Apple iPod classic MP3 Player
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Hi-speed USB device plugged into non-hi-speed USB hub
Hi Shiva,
Did you try to boot into your BIOS and check the settings for your USB port? Often you can set the compatibility mode there.
Secondly, try to connect the usb device to different USB ports on your PC, they might not all be connected to the same controller (front or rear for example).
Jules
Aug 24, 2008 | Microsoft Windows XP Professional With...
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Webcam not working
Hi speed USB Device attached to non Hi Speed Hub.... this message appears because the USB hub controller is not updated. Try to download USB 2 driver from the following. http://www.softwarepatch.com/tips/usb2-driver.html
Another application already using webcam--- for this error message... try this.. right click my computer. Properties-> hardware tab. -> device manager. check any abnormal marks like a yellow circle or yellow question marks in the cam . also check the COM ports.
Dec 29, 2007 | Microsoft Office Outlook 2003 for PC
A-hi speed usb device is plugged into a non-high spped usb hub
this usually happens when you plug a 2.0 usb device into a 1.0 device. If your appliance works then i wouldn't worry about it but if you have older technology then it may be time to upgrade
Dec 24, 2007 | Computers & Internet
Samsung yp-k3
1. You can download the software from the samsung website
2. The usb message is nothing - it is just telling you that you have a USB 1.1 hub but you well get better transfer speeds using a USB 2 hub, or you can connect it to a usb port directly
Oct 22, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 Player Logo
122 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
