Question about Mitsubishi WS-48311 48" Rear Projection Television
I have a WS-48311, lrss then 8 yrs old. When you turn it on the power light comes on and goes out in a few seconds.
  • 70 Answers
Could be just end of bulb life. with it being 8 years old. get a manual for it and look in there what is suposed to happen at the end of the bulb life.
Posted on Aug 25, 2010
Power surge from storm. Power light turns on for 2-3 seconds and goes off. Previously had a power supply replaced 3 yrs ago. tv is approx 12-15 yrs old.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
before you rate this information or if you have questions let me know what you find.
SD TECH
Jul 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My 8yr. old ws-48511 TV boots up (green light blinks shortly then goes out) after being pluged in, but when you turn it on, the green light comes on then goes off. (will not power on).What is the problem?
When the set powers off after pressing power try pressing the menu and input buttons on the set both in together and hold for 6 seconds to see if the power indicator will blink a two digit blink code which repeats a few times indicating a specific error. Let me know the blink code if any.
Jul 14, 2011 | Mitsubishi Televison & Video
Mitsubishi WS-48311 projection model. It started turning off for no reason and I would turn it back on while watching a program. Then it went off and will on come back on. Then you press the power button...
gtl545,
This model has a known defect. The power supply board and DM boards have failed electrolytic capacitors. No spares are available from the factory. Fortunately there are after market repair kits available. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem as well as where to get parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 26, 2011 | Mitsubishi WS-48311 48" Rear Projection...
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Turning off when trying to turn tv on..
If power light comes on for a few seconds and then goes off: On the front of the set press and HOLD both the menu and input (device) buttons at the same time for at least five seconds and then release both.
The power light should blink a two digit error code: 2 blinks, a pause and 2 blinks is the most common.
Tell me model number and what error code you find and I will tell you what it means and if possible what needs to be done.
This is a self check feature all WS model numbers had.
SD TECH
Apr 27, 2010 | Mitsubishi WS-65513 65" Rear Projection...
WS-55819 TV, about 8 years old, stopped working. No picture, just black. When trying to turn on, power light appears for a couple seconds, then turns off. No other indications of life. My kids...
DO THE SELF CHECK YOUR SET HAS:
When you turn it on and power light goes off in a few seconds;
On the front of the set push and hold both the Menu and Input (Device) buttons for at least 5 seconds and release both.
Power light will then blink a two digit code, most common is 2 blinks, a pause and 2 blinks--it will repeat the code at least 5 times.
Let me know what code you find and I will tell you what it means and maybe what is wrong with your tv.
I hope you find 2,2, as that is the most easy to fix.
If this helped you rate this solution as I do this here for free.
SD TECH
Jan 14, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Wont turn on. Green light comes on for a few seconds, andthen goes back o0ff.
Hi if its a Lcd or Dlp rptv most likely its time to replace the lamp if tv is between 2-4 yrs.If you hear clicking it could be the ballast which is the board that powers the lamp.Make sure fans are running ok ,dust them out if they are dirty.God bless you!
Oct 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Power cuts off at sart up
I have the same problem with my mistubishi projection tv model ws48311 I believe the problem I had before and it was a couple of transistors and a high voltage power supply that fixed it. I believe the problem was caused by faulty power from a power strip or outlet not making a good connection and sparking. I had Overland Tv in OP Ks look at the Television, but heard bad reviews from a coworker and now do not trust them hsnitkoff@yahoo.com
Aug 22, 2008 | Mitsubishi WS-48311 48" Rear Projection...
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WS-48311 48" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
