Question about Smart Modular SV3170A
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it?
  • 17,130 Answers
The fault is within the monitor. It is trying to power on but there is an hardware issue that checks to protect and cuts off power.
So check on monitor board for a failed driver. It can also be fault in the large value capacitors in this output section.
Look out for the output voltage , where the cut off takes place disconnect the section to confirm,
use a multimeter to check for the short of the suspected components.
check for voltage in these sections.
Hope this advice helps.
Posted on Aug 25, 2010
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Sampo LCD PD-80A monitor screen blinks on and off every 4...
I just replaced the relay on my second-hand NEC2010X . It would go out after some period of time, but come back if I unplugged it and then plugged it in again. It finally died altogether, but when I replaced the relay, it worked fine. Apparently this relay is the weak link on many LCD's (probably the only moving part in the whole thing). So open it up, unsolder the relay, and put in a new one.
Dec 24, 2007 | Elo 1724L (Dark Gray) 17 in. Flat Panel...
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Samsung LM1770A 17
Most probably the Power Supply, generally is in these things... perhaps the Electrolytic Capacitors have Dried out and gone bad and need to be replaced, often all I do is replace every large Electro on the Power Board, (Often with much higer Temperature and spec Caps) and that "Fixes" it..
Jul 13, 2007 | Samsung Techsan LM1770A 17" Monitor
Smart Modular SV3170A Logo
29 people viewed this question
Top Smart Modular Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
