Question about Kitchen Ranges
What is the recomended and required AMPS for electric stove instalation to avoid fire hazard? I live in Massachusetts.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573508
Generic problem for all Kitchen Ranges
What is the recommended and
Posted by kukla61 on May 05, 2008
What are the recommended and required AMPS for electric stove installation to avoid fire hazard? I live in Massachusetts.
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
Most of the electric ranges have either a 3 prong or a 4 prong gray electric cord that usually has a 220 plug, follow the color wires and match them to the wiring panel in back of the range. I am not sure on the amps, you may want to check with your local appliance dealer and also the customer’s owner’s manual, so check on the plug in the wall and then purchase the correct plug according to the number of prongs in the outlet and once installed level the range with the leveling legs. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. You did not give me a brand name or model # so check with the silver tag on the actual appliance and sometimes that will tell you the number of amps.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Posted on May 05, 2008
Bylss 34hfu600grt electric fire. Where can I get instructions?
[PDF]LDBL2000A-DD5R EN - Free Instruction Manuals
www.free-instruction-manuals.com/pdf/pa_843360.pdf
CAUTION - Fire, electric shock, physical injury and material damage hazards: To use the appliance, always follow the instructions for and assembly, use ...
BLYSS 34HFU600GRT KURZ User's guide, Instructions ...
www.manualspoint.com/results.php?...BLYSS%2034HFU600GRT%20K...
User's guide, Instructions manual & Installation guide - Immediate download or search mode services.
Jan 07, 2016 | Home
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-install-a-subpanel.html
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
Nov 04, 2012 | Bryant Westinghouse Bqc Quad Circuit...
Electrolux E48DF76EPS Slight hitch on installation. Electrical specs say connected load is 44.2 amps, requires 50 amp circuit. Trouble is, pigtail on stove (put on at factory) is #10 wire. Since...
Your stove should be fine to install when the say 44.2 AMP that means that IF YOU HAVE ALL YOUR STOVE WORKING AT THE SAME TIME you will over load it, using as normal with 1 or two plates plus the oven should not cause a ploblem you have a FUSE system that will kick out on overload, enjoy your meal
May 09, 2017 | Electrolux E48DF76EPS Dual Fuel Range
I live in a mobile home with a westinghouse DP 200 amp main breaker. it trips alot when i run the stove and the dryer along with other items.
You need to run a new circuit to the stove before your electrical wires catch on fire. that is a hazard you have taking a big chance if left alone. Your old wires and breaker is not heavy enough to run both so a complete rewiring job will be in order if not reaired very soon I would say from past experiences I've encountered
Jan 18, 2010 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Electric service requirements
Number 6 wire and a 40-50 amp breaker. Anything smaller will overheat and become a fire hazard, especially at 139 feet.
May 11, 2009 | Whirlpool Kitchen Ranges
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
Does my 3 wire dyer cord supose to go all the way in the outlet plug?
Yes. Failure to ensure the plug is flush inside the outlet, leaves 220-240VAC exposed on the terminals. This presents a potential shock hazard and/or fire hazard if anything was to fall behind the dryer and end up lodged on one of the terminals. Some of the plugs will fit very tightly inside the wall outlet. However, if the plug does not insert properly, you may require an electrician to install a new outlet for you. If you are not familiar with electricity, I would not recommend attempting to repair an outlet on your own. As I stated before, the voltage potential is 220-240VAC with a current rating of about 25 to 35 amps. I hope this answers your question. Let me know if you still require assistance.
Sep 24, 2008 | Dryers
To install electric stove ...what is the recomended and required amps number
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573502
To install electric stove ...what is the recommended and required amps number
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
