Question about Kitchen Ranges
To install electric stove ...what is the recomended and required amps number
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573502
Generic problem for all Kitchen Ranges
Posted by kukla61 on May 05, 2008
To install electric stove ...what is the recommended and required amps number
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
Most of the electric ranges have either a 3 prong or a 4 prong gray electric cord that usually has a 220 plug, follow the color wires and match them to the wiring panel in back of the range. I am not sure on the amps, you may want to check with your local appliance dealer and also the customer’s owner’s manual, so check on the plug in the wall and then purchase the correct plug according to the number of prongs in the outlet and once installed level the range with the leveling legs. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. You did not give me a brand name or model # so check with the silver tag on the actual appliance and sometimes that will tell you the number of amps.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Posted on May 05, 2008
Electrolux E48DF76EPS Slight hitch on installation. Electrical specs say connected load is 44.2 amps, requires 50 amp circuit. Trouble is, pigtail on stove (put on at factory) is #10 wire. Since...
Your stove should be fine to install when the say 44.2 AMP that means that IF YOU HAVE ALL YOUR STOVE WORKING AT THE SAME TIME you will over load it, using as normal with 1 or two plates plus the oven should not cause a ploblem you have a FUSE system that will kick out on overload, enjoy your meal
May 09, 2017 | Electrolux E48DF76EPS Dual Fuel Range
I have a wall oven that I am installing. Three wires - 12 gauge Black, 12 gauge Red, and a smaller gauge White (no number) looks like 14 gauge. What gauge do I need to run to the panel and what color to...
all wall ovens and freestanding stoves require a 50 amp breaker
you need to check the electrical codes in your area but i would use a minimum of 12 gauge wire if not even 10 gauge
Jul 21, 2011 | Kitchen Ranges
How do I know if my stove is three fase. I am in Brazil and the here power is 220v. Would you help please?
Your oven is 2 phase 220 volt not sure about foreign electrical service.The stove requires 2 phase electric service,each leg impute can be no more than 135 volts.It requires 2 pole 60 amp service with no less than a 8 gauge 3 wire service line with ground.The pigtail on the stove is as follows,black wire 120 volt leg red wire the other 120 volt leg the white wire is the neutral leg,(which is sometimes run to the ground block which incorrect but will work) the green wire is ground.
Jun 13, 2011 | Whirlpool Stove Oven Sensor 8053344
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Electric service requirements
Number 6 wire and a 40-50 amp breaker. Anything smaller will overheat and become a fire hazard, especially at 139 feet.
May 11, 2009 | Whirlpool Kitchen Ranges
Amperage Requirement
an electric stove requires a 40 amp double breaker in the fuse panel. good luck. Also read the manual to make sure.
Dec 16, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Need electrical information for electrician to install new power
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
Dec 01, 2008 | Jenn-Air JDS8850 Dual Fuel (Electric and...
What is the recomended and required AMPS for electric stove instalation to avoid fire hazard? I live in Massachusetts.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573508
What is the recommended and
What are the recommended and required AMPS for electric stove installation to avoid fire hazard? I live in Massachusetts.
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
562 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
