Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity FAFW3577KA1 washer - about 1 month old, keeps stopping at about the 12 minute mark of a cycle and won't finish draining. It pauses itself, we press start/pause button to restart and we start from 12 minute mark again - over and over and over. If we can get it to unlcok after several of these cycles, we just wring out our clothes and put them in the drier. Technician is coming later this week but over-the-phone main service from local appliance store suspects control board. I have already given much detail to leveling nd standpipe / drain tube height. Both of those are good - even after taking riser into account for the minimum standpipe recommendation.
  • dan_grisez Aug 27, 2010
    Combo washer dryer sheets are to blame according to repair technician. The lint-like debris from these sheets was clogging the filter on the washer pump.
IB4G2008
  • 3587 Answers
SOURCE: Washer discharges Water during Agitation
you might consider raising the washer about 6 inches to make this work. it's vital to the operation of the machine..
Posted on Mar 09, 2008
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
  • 100 Answers
SOURCE: keep stopping pausing
If you leave the machine to itself, will it go through the whole wash satisfactorily? If it does, then the start and stop is designed into it. What it is doing is stopping and reversing the washing action. That is so the clothes will not wind up in a long rope shape, like the winding up of a towel like you use to do to a towel to snap your bother or sister in the showers or at the pool. It UNWINDS the load... It goes a few turns one way, then pauses, then a few turns the other way and pauses. Hope this helps..... 2529817.gif
Posted on Dec 01, 2009
beltronic205
  • 1466 Answers
SOURCE: Front Load washing machine ! What is the min
The hose will be a standard lenth so thats ok the Height you want about 3 ft..above floor level
Posted on Mar 31, 2010
whybuya
  • 41 Answers
SOURCE: Frigidaire front load washer #GLTF2070CSO Was
Unplug the machine for 24 hours and try again.
Posted on Feb 24, 2011
Cycle stops at 12 minutes remaining in all cycles. Sounds like a grinding noise in unit. Then machine stops with Water remaining in drum. No blocks in pump. I run spin only to empty water. E11 code
Thanks for your post, Daniel!
Based off the information you have provided the cycles inside of your Frigidaire washer will stop at 12 minutes and making a grinding noise. I also see that you receive an E11 error code and that stands for a long fill time. I would recommend checking over the hoses to assure they are installed properly and not restricted. You may have an issue with your drain pump, motor, or water valve. I would recommend performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. I hope this information is helpful to you. -Matt
Dec 22, 2015 | Frigidaire ATF8000FS Affinity 3.5 Cu. Ft....
Reset frigidaire affinity washer
Yes there is buy a new drain pump so all the water will get out
Jan 19, 2014 | Washing Machines
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity washer stopped working. When i start the cycle it makes a loud humming noise, but no water goes in, and it starts spinning for a few minutes, then the time goes from 1hr, to 3 m
Possible that the inlet valve is faulty. please measure the voltage on the inlet when the washer is switched on , if there is no voltage then the controller is faulty. If voltage is present then the inlet valve has failed.
Jun 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
My Frigidaire Affinity Model atf6000fs0 Washer presents two error codes at beginning of each cycle - EF0 after about one minute and the E10 after a few minutes - cycle stops there. Nothing else happens....
My Affinity (M - ATF6000FS0) fails to an E-20 code. The troubleshooting guide helped; however, the code continues to come in. The drain line is clear to the pump, but the pump sounds like it is failing. Guidance, insight, feedback....please!
Feb 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
199 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
