Question about Indesit W 123 Front Load Washer
Your solution "error codes Indesit" 107 message --------------f10---f2
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
Tip
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F01 - Short circuit motor triac
  • F02 - Motor jammed tacho detached
  • F03 - Wash thermistor open/short circuit
  • F04 - Pressure switch jammed on empty
  • F05 - Pressure switch jammed on full
  • F06 - Program selector error
  • F07 - Heater relay stuck
  • F08 - Heater relay cannot be activated
  • F09 - Incompatible eeprom
  • F10 - Pressure switch not sensing correctly
  • F11 - Pump cannot be activated
  • F12 - Communication error
  • F13 - Dryer fan or dryer thermisotor fault
  • F14 - Dryer element fault
  • F15 - Dryer element relay fault
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
When I am trying to boot up my Laptop ''Packard Bell Easynote'' I get the following message: Resource Conflict - Allocation error static node #0B Warning: Cannot Unlock Primary HDD Press Enter to resume....
you can fix that problem with your own. press f2 and then correct the time and date, then press f10. I f you got same problem again change the cmos battery then do it again.
Feb 15, 2010 | Computers & Internet
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
Nov 19, 2009 | Sharp AR-C260M All-In-One Printer
I just got this machine and it hangs on the POST (with video) about 1/4 of the way. This is before the F2 or F10 message comes up. Two days ago, I took the CMOS battery out and put it back in and it did...
POST errors can be difficult to diagnose.
If you have a speaker attached, listen for a sequence of short and long beeps, and pauses between. Record the sequence, this is a code that tells what the POST diagnostic is.
Other start up BIOS keys are F2, F6, F8, F10 and F12; when I don't know which one it is, I just hit all of them.
Whether it's stated or not, you can usually hit these keys during the memory count, (The second Self Test after video)
If the Memory Count dosn't finish and the BIOS open, then perhaps a dammaged memory chip is the cause. Try Rearranging the chips, or removing all but one of them and try the boot sequence.
This may not be a solution but further info can be gained by trying these.
Jun 18, 2009 | Dell PowerEdge 4400 Server
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Wf860 Error Code: F10
hiya
this could be caused by a faulty pressure switch (controls water levels). but due to the machine sharing the same electrical components as indesit it could be a fault on the main pcb.
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Jul 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Indesit W 123 Front Load Washer Logo
140 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
