Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore refrigerator not cooling
We have a Kenmore refrigerator with a top freezer and it is not cooling. It started out by leaking out the freezer door and things in the freezer were thawing. We turned it up and it worked for a couple of days, then same problem. My husband pulled it out and vacuumed everything and tried blowing out the drain hose in case it was plugged. He said the condenser was very hot, everything seemed to be working, but the freezer is not cold and now the frig is warm also.
Any ideas?
  • MikeBRMI May 05, 2008
    Would it still be frozen up if any ice is gone? It has thawed 3 differnet times and was completely clear yesterday when we pulled it apart.
Freezer is working put refigerator on top is nott
Posted on Jul 06, 2008
  • 828 Answers
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
Posted on May 05, 2008
  • James Helmer
    James Helmer May 06, 2008
    The statement that the condenser was hot would indicate to me that the compressor is pumping heat. If it is indeed the compressor that is hot the answer would be different. If it is the compressor that is hot it indicates that the problem is with the compressor itself. If it is covered by warranty it should be replaced, if it is out of warranty (over 5 years old) the whole refrigerator should be replaced.
It leaks inside the refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Top Freezer Refrigerator
Kenmore model# 79573966 - Top Freezer Ice is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Jun 03, 2011 | Kenmore Top Freezer Refrigerator
Condensation/water is leaking inside the fridge below the freezer
heatman101
May 23, 2011 | Kenmore 64814 / 64812 Top Freezer...
My fridge is leaking water from the freezer into the fridge
heatman101
May 19, 2011 | Kenmore Top Freezer Refrigerator
Our kenmore refrigerator is leaking water from the freezer into the refrigerator
heatman101
Apr 25, 2011 | Kenmore 64262 / 64264 / 64269 Top Freezer...
Water leaking from the bottom of the refrigerator
heatman101
Apr 01, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking from fridge roof
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water leaking from freezer box onto top self of frig. Has to be wiped once a day.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
heatman101
Mar 11, 2011 | Kenmore Refrigerators
Kenmore 253.78989801. Refrigerator stop cooling, then freezer gradually lost temperature. Melted ice buildup on coils by removing panel in freezer. Restored power. Fan in freezer works, I can hear...
If freezer is not cooling then the chance of frost forming is also out of question. So we need to start of by checking on the prrimary component, the compressor. Make sure the speed of the motor is humming welll or check the motor capacitor. Use a clamp tester to measure the current factor to see the load. If the pumping is low then check for gas pressure in the unit. If not you will need to check why the gas leaked check the leak with compressed air pumped in and monitored.for leak.
Only then recharge gas and seal.
Test the motor before gas filling to confirm the performance.
Sep 16, 2010 | Kenmore 74173 / 74170 Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
524 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
