Ican not turn it on
I plug it into a live/hot receptical/surge protector and it doesn't turn on
  • Brownster Jun 16, 2008
    Plug fax machine into power surge protector, tried in a live outlet in the wall also and no power?????
  • Felix Gomez
    Felix Gomez Sep 01, 2008
    Same problem here. Everything was fine until a power outage from a storm. No power to the LED panel or any other part. Tried looking for a reset. Manual & online support didn't help. Didn't hurt anything else plugged into the same suppresor. Tried straight outlet, everything. Give it a cremation? Thanks in advance...
    President:
  • 2,072 Answers
Either the power switch or the power supply have failed.
Hard to determine without knowing the make or model though
Posted on May 05, 2008
L E D christmas lights stay on when shut off.
No it's not. Your LED Christmas lights are okay. Your surge protector is fine too although the switch on your protector is an SPST type - it is connected to one line of your AC outlet. When turned off, the line with the switch is physically cut, but the other line is still alive. Some LED circuits and TFL lights blink even when the switch is turned off, probably because one line of the AC power is still (a)live. If this worries you, just unplug the LED lights from the protector.
Nov 23, 2013 | Garden
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
I have a Toshiba BDX2100 Blu Ray player. I've owned it since October 2010. I've not had any problems with it until a couple of days ago. It won't turn off unless I unplug it, and it only opens...
Do you have the Blu Ray player plugged into a surge protector, sometimes surge protectors can cause odd feedback in certain electronics and cause them to be buggy. If this is the case, take it off the surge protector and plug it straight into the wall and see if that fixes the problem. If this isn't the case or doesn't solve the problem there could be a number of reasons this is happening, there could have been a surge that fried some internal components causing the player to not function correctly, or it could have just had a hardware malfunction. If this doesn't help I would recommend calling the manufacturer of the player to see if they can provide you with additional info
Jul 18, 2011 | Video Game Consoles & Games
My window unit got hit by lightning and blew the plug right out of the wall, although it had a surge protector on it- it does not work now- any ideas on what I could try to fix it like a new fuse or...
As you saw a surge protector doesn't stand a chance against lightning!!!
The unit is toast... turn it into homeowners and buy a new one...
heatman101
Jul 12, 2011 | GE Heating & Cooling
Hpscanjet 2400 is not powering on,what maybe the problem?
• Ensure that the power cable is securely connected between the
scanner and a live electrical outlet or surge protector.
• If the power cable is connected to a surge protector, ensure that
the surge protector is plugged into an outlet and turned on.
• Disconnect the power cable from the scanner and turn off the
computer. After 30 seconds, reconnect the power cable to the
scanner and then turn on the computer, in that order.
Jul 07, 2011 | HP ScanJet 2400 Flatbed Scanner
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
29 people viewed this question
k24674
jasbo
jasbo
