Question about Microsoft Windows XP Professional
I cannot open my drive d. the properties, 0 bytes what happen? what should i do?.. anyone could help..
    Guru:
  • 632 Answers
Check IDE connection inside case could have come loose if not its a broken drive.
Posted on Aug 25, 2010
Unable to format usb stick
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Aug 05, 2012 | Dane-Elec DaneElec 4GB USB Drive Copper...
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My SanDisk Cruzer Gator 4GB is not working. When
The filesystem appears to be corrupted. Try right-clicking the drive's icon, going to Properties, Tools and Check Disk. If that doesn't help the partition that holds the data may be unreadable, and if that happens try asking a data recovery service if the data is important.
Jul 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SimpleDrive 160 GB drive is recognized by XP, but cannot access. Have tried on 4 computers. Properties show 0 bytes size and 0 bytes free. Can't even Format Drive. This happened after interrupting an...
The drive was damaged during the interuption. This has happened to alot of my flash drives and there is not way to fix it. You can, however, replace the hard drive in the case. Open the case and you will see a small laptop hard drive (that's all it is), purchase a new replacement and throw it in there.
Oct 04, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
Usb flash drive corrupted
try other usb port, or other computer, if still have problem, download a usb recovery software, one I used before is Asoftech Data Recovery, you can follow this guide for usb recovery
usb file recovery guide
Oct 18, 2008 | Electronics - Others
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Microsoft Windows XP Professional Logo
15 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
