Question about Cell Phones
I cannot reconnect to bkuetooth earpiece was paired but deleted the pairing and now can't reconnect
    Guru:
  • 632 Answers
Delete all other paired devices on your phone before reattaching it.
Posted on Aug 25, 2010
How to pair my bb curve to uniden BT112 bkuetooth
You need to put the bluetooth into pairing mode.
Jun 26, 2012 | Blackberry Curve 8350i
tell the person with bt112 bluetooth to pair with you.. their will be a thing that pops up on your phone that says enter pair code just put 1234
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Oct 14, 2010 | Plantronics CS70 Wireless Headset
Need help pairing
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Feb 28, 2010 | Plantronics Explorer 330 Headset
Earpiece won't link to phone anymore
Hi Josh,
there may be a battery or an internal antenna failure on your headset.
You might try re-pairing the devices if you can.
Jan 08, 2010 | Motorola Mobility H700 Wireless Headset
How do i put my 510 earpiece in the pairing mode
Press and hold the switch for about 30sec ...after that it will be in pairing mode ...and enter 0000 as passkey
Oct 20, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
Changing phones but same Bluetooth earpiece
apparently deleting the earpiece from my SE devices did fix the problem, i just hadn't realised. thanks
Dec 07, 2008 | Lands Phones
LG Shine KE970 Bluetooth issues
the pass code is always zeros trust me
Nov 07, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
99 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
