Question about Kyocera Mita KM-1650 All-In-One Printer
Ram error F020 - Kyocera Mita KM-1650 All-In-One Printer
Hello, I have a Xerox 4510 DT that shows the error: RAM ERROR. I have had the users shut down the machine, wait a minute and then restart but the error still shows. What else can I have the user do?
You can try inspecting and moving the ram to the other RAM slot. The 4510 image processor board has 2 ram slots, so one of them should still be unused. To access the ram you must remove the right side cover. Its possible changing the slot the ram is in will fix this, if it does not the next step would be to replace the ram. Part# 133K27760 for 128MB. Finally, if after replacing the RAM the error continues you would need to replace the image processing board. (part# 960K41806). Hope this helps
Aug 01, 2011 | Xerox Phaser 4500 Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Hai, i want to ask for my F020, why my F020 always ask for simcard..?? if i take the battery,it's solve for a second (it wont error again), but sometimes it will error again.. what should i...
hi..
press 3,#,*,continously and press switch off /on button then switch ON it automatically format your phone and then the problem will be rectified..
then again it happened means check the hardware of your phone whether your phone sim insert lock is seated correctly or no chect it that....
good luck
If it's useful for you means plz rate me the 4 Thumbs ....
Jan 06, 2011 | Cell Phones
Error message 20
F020 Main or expanded memory error
1. refix the main board and try.....
2. replace the expanded memory of the printer ........and try.......
3. replace the main board.........
Oct 21, 2009 | Kyocera FS-2000D Laser Printer
Paper fed through the Multi-purpose tray exits from the rear of the machine rather than from the top.
There will be a setting in the printer. Most people have it set to exit straight through as they run card stock from multipurpose tray. Should also be setting in print dialogue box
Apr 24, 2009 | Kyocera Mita FS-C5016N Printer
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Ram error on a 6250 xerox printer
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 28, 2008 | Office Equipment & Supplies
Phaser 6250 "Ram error" (?)
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
Kyocera Mita KM-1650 All-In-One Printer Logo
166 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
