Question about CDV Software Codename: PANZERS Phase One
I've installed Panzer Phase 1 onto my laptop but it won't start. Any help?
Does anyone know where I can buy online after-market decals for an Ialeri brand 1/35 German Panzer I model?
It would help if you first find some pictures of the actual tank, then you could try contacting this company: http://www.model-supplies.co.uk/ or other companies that make reproduction decals for models and old toys. The Maidenhead Static Model Club is another possible contact point for you to try. Good luck!
Jan 08, 2015 | Crafts & Hobbies
I have an HP G42 the laptop won't boot or start
HP laptops are well known for motherboard issues, and will usually involve a replacement board, at this point have it checked before a decision is made.
Sep 26, 2012 | Computers & Internet
Barnett panzer v crossbow cocking hand crank
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try using another brand you might have a bad batch of dvd's
hope it helps
Nov 14, 2011 | Barnett Crossbows Barnett Panzer V...
No pwer at all going to driving light nor the instrument cluster, starter turns but it won't turn on .and on the fuse block some of the fuses have no power running to them .the fuses are still good
Sounds like you have a power drain (small-amperage short) in the wiring going to your instrument cluster. The short has disabled some of your instrument cluster lights, but, since is has high resistance, it has not blown a fuse (since it draws to few amps). Once the current drain has wasted enough amperage, there's not enough left in the battery to start the car.
Phase 1: Interim solution: (1) charge the battery with your battery charger (if you don't have a battery charger, attach the battery with jumper cables to the battery in a running car - its alternator will charge your battery).
(2) pull the fuse(s) to the instrument cluster, thus killing power to the short.
(3) start and use you car without instrument cluster lights until you can move
to phase 2 of your repair. If you're not sure that you've killed power to the short, disconect the battery each time you stop the engine.
Phase 2:
(1) isolate the problem (the short) to one specific fuse, meaning one specific branch circuit in the car.
(2) trace the wiring from the fuse block to the instrument cluster, looking for
burn marks, bare wires (all wires should be insulated), or anything touching
a frame ground. Also look for moisture iintrusion - water can cause these types of high resistance "shorts" - with the symptom that the problem disappears after the water dries up.
(3) correct wiring problem found in step 2, plug in fuse. done
(4) if replacing instrument cluster, use instructions below.
1995-99 Models
See Figure 4
Fig. 4: Common instrument cluster found in 1995-97 "S" series Pick-ups.
(see illustration at end of message)
1. Disconnect the negative battery cable.
2. Remove the sound insulators/trim panels.
3. If necessary for access, unfasten the steering column nuts and if necessary, the bolts at the lower flange, then lower the column for access.
4. Unfasten the instrument cluster bezel screws located at the lower edge of the bezel. If no screws are present, then remove the bezel by pulling it straight out.
5. Unfasten the four screws retaining the instrument cluster to the instrument panel, unplug any necessary cluster electrical connections, then remove the cluster.
To install.
6. Install the cluster to the instrument panel making sure the cluster is firmly seated onto the connector, attach any necessary electrical connections and tighten the cluster fasteners to 17 inch. lbs. (1.9 Nm).
7. Install the instrument cluster panel bezel by snapping it into position, then if equipped, install the screws along the bottom of the bezel.
8. If lowered, re-position the steering column and tighten retaining nuts to 22 ft. lbs. (30 Nm) on 1995 models. On 1996-99 models tighten the nuts to 20 ft. lbs. (27 Nm). If removed, tighten lower flange bolts to 120 inch lbs. (13 Nm).
9. Install the sound insulators/trim panels.
10. Connect the negative battery cable.
Sep 26, 2011 | 1996 Chevrolet Blazer
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
I installed panzers phase 1 on win7. all installation was trouble free but when i try and start the game i'm asked to reboot to finish installation but when i reboot and then try to launch the game...
Have you tried to uninstall and reinstall the program?
is your windows 7 a 64bit or 32bit?
if 64bit, maybe the program is not compatible with win7 64bit.
try this one.
  1. right click the shortcut link of panzer.
  2. on the menu choose Properties.
  3. then click the Compatibility Tab.
  4. On the Compatibility Mode >>>> Check the Box that Says " Run this program in compatibility mode for: "
  5. Choose the compatibility you want in the drop download list ( I Suggest you choose Windows XP SP2 )
  6. then click apply then Ok.
  7. Run the game.
Hope it helps.
Jun 28, 2011 | CDV Software Codename: PANZERS Phase One
I,ve got a problem starting my 97 hyundai lantra 5dr sedan. i think it has something to do with the switch on the cluth, car normally won,t start unless clutch fully engaged,. i,ve got a new battery and...
try pushing the clutch to the floor with you toes if it starts and won't unless you push to the floor its the clutch start switch 22 bucks at auto zone i will be gettng help installing the new one i will let you know.
Oct 08, 2008 | 1995 Hyundai Elantra
CDV Software Codename: PANZERS Phase One  Logo
37 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
Bill Boyd
Steve Mason
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
