Question about Garden
Brakes quit working when you push pedal down on simplicity riding mower
    Brigadier General:
  • 3,911 Answers
I know for a fact that you can download owner's manuals and illustrated parts lists at the simplicity website as i downloaded them for mine. they are quite detailed and show "how to" for adjustments, etc. go over there, and download the manual and follow the instructions. Google "simplicity mower".
Posted on Aug 25, 2010
How come my Simplicity Regent 38 rider, stall out when I release the brake pedal?
Change air filter or inspect ignition or plugwires. Clutch n gears cud hav issue
Oct 20, 2015 | Garden
Troubleshooting a Simplicity regent lawn tractor engine thta stops when brake/clutch pedal is released
there is a safety switch underneath the seat thats purpose is to shut the motor off if mower is engaged with no one sitting on the tractor.It sounds like this switch is faulty or there's a bad connection there.
Jun 17, 2014 | Briggs & Stratton Garden
Simplicity regent lawn tractor engine stops when releasing brake pedal
That is a faulty nutral safety switch that is causing the problem
I have a John deere L108 ride Mower with a problem with the break pedal The brake pedal is pushed or the linkage is stuck in the "brake" position.I have disconnect from the diff but unable to...
if the linkage is free it is probably the caliper. you may have to take it off and work with it to get it free. they get stuck from rust sometimes. there is videos on you tube that show how to do this.
Feb 21, 2018 | Garden
I friend has a craftman riding lawnmower with a problem, when the brake pedal is push down the engine will run, but when you released the brake pedal the engine wants to shut down, also when you pull the...
The drive pulley underneath has an arm with a rubber brake that rubs against the pulley when the brake pedal is released. Make sure that it is not jamming or defective.Let me know if this helps
Jan 19, 2011 | Craftsman Garden
Mower will not free wheel.brakes off and hydros released
You have to do one more thing to move this tractor without the motor running.
It takes two people to move the Revolution. One needs to sit on the seat and hold the forward pedal down. It will then freewheel.
So, brake off, both hydro release levers pulled (do NOT pull hard or you will break the springs) and the forward (right hand side, big pedal) pedal pushed down.
Any other question? I know this unit pretty well.
Dec 30, 2010 | Craftsman Revolution 42" Briggs Stratton...
Replaced the drive belt. pushing down on break pedal will not completely stop my mower.I must have missed something/ Thanks
only that you never took up the slack in the brakes,,, take it up a bit more and the brakes will work ok then,,,
Aug 14, 2010 | Garden
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman hydrostatic strains but won't go forward or reverse
There is a brake lever attached to your transaxle, that when activated, pushes dowel pins which serve as brake pistons, against a brake pad which presses against a disk from your transaxle...whew. Much like a disk break on your car.
The pistons, or dowel pins may be sticking, causing you to be "riding your brake". A little disassembly and some good ole WD-40 might loosen up the bind.
Aug 25, 2009 | Garden
Garden Logo
183 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
