Question about Krups Small Appliances Espresso Machine
My Krups coffee pot model number KM406 will not brew coffee I have redid all the setting and have followed troubleshooting manual This doesn't make for a good first day of school in the life of a teacher
  • 5 Answers
SOURCE: does not brew a full pot of coffee
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Posted on May 23, 2008
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Posted on Mar 08, 2009
SOURCE: Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Posted on Jun 13, 2009
  • 145 Answers
SOURCE: kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
  • 186 Answers
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Posted on Nov 05, 2009
When I brew a pot of coffee all of the grounds do not get wet Why?
Hello, Vicky -
It will help in answering your question to know the make and model of your coffee maker. You can choose Comment and add that information in the Comment box.
As a general answer, there could be 2 reasons for all of the coffee grounds not to be wet:
* You may be using a dark roasted coffee, which has a high amount of surface oils , making it difficult for the water to wet all the ground coffee beans during the brewing process. If so, you may need to follow the "hot bloom" method when setting your coffee maker up to brew. Watch the video here:
https://www.bruer.co/blogs/news/113462276-the-hot-bloom-method-eliminating-dry-coffee-grounds
* The spout for the water to dispense in your model of coffee maker may have become positioned off-center
Along with only partially wet coffee grounds does the brew seem weak?
I assume you have already checked the user manual for your coffee machine to find if the partially dry coffee grounds issue is addressed in the Troubleshooting section. You may wish to visit the website of the manufacturer of your coffee machine to find if the problem is covered in FAQs or Troubleshooting for your model of machine.
Best wishes.
Feb 15, 2018 | Coffee Makers & Espresso Machines
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Krups KM7000 won't make a full pot.
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Oct 18, 2012 | Krups KM7000 10 cup Grind and Brew coffee...
Coffee maker won't brew
the pump inside the unit it either clogged or broken
Jul 14, 2012 | Krups Coffee Makers & Espresso Machines
Krups km406 will not brew coffee
could be clogged pump or bad pump, I have also seen where you need to let the water reach a certain temp. before it will begin to brew
Jul 14, 2012 | Krups KM4065 12-Cup Coffee Maker
OH Yeah!
EfACTOR
Feb 22, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
How to keep coffee heated after brewing
I beleiv this model is like a thermos ,once it brews you can take the pot and place on a table for company,so that you dont have to keep getting up to get more,a lot of breakfast places use this method so the waitress is walking around all the time with a hot coffee pot,if your losing heat make sure the top is secured please rate this solution thanks
Jul 13, 2008 | Krups Aroma Control 229 Coffee Maker
Setting the automatic brew timer
Go to this link armed with your model number and you should be able to download the manual http://www.cuisinart.com/manuals/index.php?cat_id=3 I hope this helps :)
Feb 24, 2007 | Cuisinart Grind&Brew - BLACK
Krups Small Appliances Espresso Machine Logo
280 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
