Question about LG LSC26905TT Side by Side Refrigerator
Frezer is frozing - LG LSC26905TT Side by Side Refrigerator
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
FREZZING WATER ACCUMLATING IN FREZER-WHAT IS THE PROBLEM.
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Hi, I have a ge profile refrigerator (double door). Recently, there were lots of ice build up on bottom of frezer, but melt water on the top. Also frozen items on the lower part of refrigrator part. Do I...
heatman101
Aug 18, 2010 | GE GBS22HCP Bottom Freezer Refrigerator
FREZER NOT FEEZING SOLID
you must defrost it. and it will work again about 3 hrs with fan blowing in the open door .. the cooling coils are froze over with ice .. kool fix
Jan 31, 2010 | Maytag MSD2651 HE Side by Side...
Frezer is working , the other side is not cooling
replace defrost timmer , evap coil is froze not leting air into fridge part of the unit.
Sep 07, 2009 | Refrigerators
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
Tow dooe refrigerator and frezer, ice in the
likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Jun 29, 2009 | Refrigerators
I was pickeing away at the ice on frezer and i poked a hole in the plate for the frezer, i need to know if the fridge will still work or do i need to bye a new one
Yes , should still work as long as you didnt hole the coolant pipes. Use some putty or similar to block the hole.
May 19, 2009 | Refrigerators
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Fridge is freezing up. not going thru defrost cycle
it is one of these 3 parts..
one, defrost heater,
two, defrost timer,
three, bi-metal or thermodisc.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
