Question about Dryers
I have 2 Defy Autodry tumble dryers that are not heating up. I have taken the first one in for repairs 3 times just to have it stop heating a few days later. The repairer didn't want to explain what he did or what was wrong. I gave up on fixing it and bought a new one. Now one year later i have the same problem. Is there something i can do without paying someone a fortune to do something simple! regards
  • 18 Answers
SOURCE: Autodry cycle never stops
you need to replace a t-stat. one of your t-stats are blown. im drawing a blank but its the one with four terminals on it
Posted on Feb 04, 2007
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
SOURCE: Zanussi TC470 Tumble Dryer - Drum not rotating
Both sound like the drive belt to me - I've just replaced mine.
BirdG is probably snapped.
mildew is on the way - the motor will burn through it if left unfixed.
you may be able to tighten it and get more time out of it but sounds like it has a worn patch and will go soon.
(tightening is easy- just remove the fan belt cover at the back,slacken the large bolt below the motor and rotate the motor to push the jockey wheel harder against the belt, then retighten the bolt.
replacing is harder.
Posted on Feb 09, 2008
  • 135 Answers
SOURCE: tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Posted on Apr 12, 2008
  • 943 Answers
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Posted on Sep 15, 2008
I have a defy autodry tumble dryer - about 5 years old. In good working order, but a few days ago when I pushed the on/off switch in to put the tumble dryer on, it went all the way in. It still works...
I have not personally seen one but in most cases with washers and dryers, access at the rear, removing a few screws might loosen the top from the back panel and that might allow the top to be pry open. The top is usually held in place with clips rather than screws...same as door panel in cars are held flush against the body of the car with clips. I would try removing the top by way of the back. Just a guess.
Feb 08, 2015 | Dryers
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
Defy autodry, comes on timer works but will not tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 15, 2011 | Dryers
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
Jul 26, 2011 | Dryers
My defy tumble dryer is not getting hot just blowing cold air
Apr 21, 2011 | Dryers
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Jan 23, 2009 | Dryers
Defy dryer, not heating
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Jan 03, 2009 | Roper RES7646KQ Electric Dryer
Jan 18, 2008 | Dryers
Dryers Logo
79 people viewed this question
Top Dryers Experts
