Question about Marantz SR-5200 Receiver
Marantz sr4200 i have just dusted off the cob webbs off of my Sr4200 reciever . but realised that i have switched the rear speakers to none in the set up menu before i put it away. i now cannot find the remote. is there anyway of accessing the menu without the remote?. or what replacement remotes would work with my amp. many thanks for your response thank you
    Problem Solver:
  • 5 Answers
I use a Logitec Harmony 520 programmable remote. I pay 80$canadian.
http://www.logitech.com/index.cfm/440/371&cl=ca,en&hub=1?selectedcrid=440&selectedcid=371
Posted on Mar 08, 2009
My Marantz AV Surround Receiver SR4200 has an over zealous protect mechanism which turns off the receiver when it's clearly not necessary. Is there any way to adjust or turn off this mechanism?
There are 2 causes of the problem that you describe. One is the input signal is too high and is over driving the amp. The other is the output impedance is dropping due to short circuit etc. There is no adjustment on the protection circuit. It is possible that a weak sensor is present or a bad transistor etc, but you need special equipment to check that.
http://www.eserviceinfo.com/downloadsm/40697/Marantz_SR4200.html
Oct 21, 2017 | Marantz Audio Players & Recorders
Is it worth trying to fix a maranz sr4200 with slight water damage
Probably not. Marantz does not supply replacement boards, so you can't just put a new board into it to replace what was damaged.
Apr 16, 2013 | Marantz Audio Players & Recorders
Quite often if I try to switch from say the DVD input to the CD or tuner input, nothing happens. I have to start turning the surround knob to make the amp switch. All my external components are connected...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR4200-Receivers-manual/id/511dj798/t/2/
I can't really find an explicit reference to it in the manual but I'm thinking it's checking the potential digital assigments first as most AVR's default to a preference for digital in, then switch to analog if the digital signal is not present or drops; and return to digital if the signal reappears.
Page 11 talks about the default and manual assignments of digital inputs. They don
Mar 07, 2011 | Marantz SR-4200 Receiver
My Maratnz SR4200 is coming up with a protect sign on the digital display. I have tried cutting off the ends of the wire to ensure dust hasn't tripped it and also am sure the wire has been entered...
Unplug all of the speaker wires. Switch it on. If it still says "protect" then the problem is internal within the receiver. If it stops going into protect mode with speakers disconnected, then the problem is possibly blown (shorted) and or incorrect speakers causing it to trip.
Feb 26, 2011 | Marantz SR7500
Hi, My Marantz SR4200 goes into protect mode about 45min after cranking the volume up to party mode, ie above '0'. It is getting worse slowly. Ok at lower volumes. Something seems to be overheating,...
Or it could be you're overdriving it, hence the heat. Take a clue and turn it down. At 70 wpc played loudly it could be going into speaker- and self-damaging distortion.
Make sure it has a lot of ventilation.
Dec 23, 2010 | Marantz Audio Players & Recorders
Connecting apple tv to Marantz sr4200. The HDMI plays video, but no audio??? I connected an optical cable, but still no sound???
Check out the sound menu on the TV you might not have it switched to digital out, or have the wrong audio mode.
Jun 26, 2010 | Audio Players & Recorders
Have to turn way up in order to hear
Have you gone into the TV's menu to make sure that the audio outoput is not set to "variable"?
On my Sony I have the option to set the audio output as "fixed or "variable"
make sure its set to fixed
if that's not it try a different input on your receiver. you can use anything EXCEPT PHONO.
Lastly on my Denon receiver I have to specify how each input should get its signal if you are using an optical cable then you may have to go into the menu and tell it to look for a digital signal not an analog one.
Hope that helps
Jan 22, 2010 | Marantz SR-4200 Receiver
Protect error on marantz sr4200
Check all your speaker wires carefully. Chances are good that a braid has crossed from + to - and causes the unit to protect itself. This is a very common problem! everyone's done it at some point. Check connections at both the receiver side and the speaker side. If you still have a problem, post a comment and I can help you troubleshoot further. Hope this helps.
Sep 27, 2009 | Marantz SR7500
Marantz SR-5200 Receiver Logo
414 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
