Question about Samsung SyncMaster 753S 17" CRT Monitor
Moniter display problem pls help me? single line in the moniter centre ?
  • Samsung Master
  • 32,281 Answers
If the line is horrizontal then the fault is in the vertical deflection circuit.
It is not worth repairing an old CRT monitor, unless you have electronic knowledge. I do not recommend repairing CRT monitors yourself, because there are dangerous high voltages inside these monitors, even though the unit is unplugged from the main outlet. The CRT tube will hold high voltages for weeks even though the monitor is turned off.
I suggest you put your money towards a LCD screen, they are inexpensive.
Posted on Aug 25, 2010
Power failure,now 000 is flashing on oven exterior
If the 000 is on the display left of centre, then you possibly just need to reset the clock. from left to right-....press the first button to activate the clock setting phase....press the next button to pop out the rotating timer adjust and set the time.
If it is the display above the centre control dial pls repost with the full Enr from the rating plate.
Feb 25, 2013 | Neff B1881 Single circotherm super...
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
Hi I am using the Acer AL1511 15 moniter from last 2years, now its not working properly. It is giving lines on the display (fully covered the display) and unable to see the actual display. Can you tell me...
look you have to either change or take it to the service centre.this problem is related to the pixcel of your monitor.this occur due to the fluctuation in the voltage signal.this cant be removed easliy.
Oct 19, 2010 | Acer AL1511 15" LCD Monitor
My power light is on but the monitor is black. Is
your moniter is not broken your moniter's data cable is not correctly pluged.
Jul 30, 2009 | Dell E173FP 17" LCD Monitor
Horijontel line to come moniter
Hi and welcome to FixYa,
Initially, pls check and replace if deemed faulty the Vertical IC301 KA2142. Additionally, you may want to check that pin 9 is getting +28VDC as supplied by diodes D303 and D301. In some instances, capacitor C627 also requires replacement. You may also want to check R307.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 11, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Display problem
how many voltiges?
You said to ask. Are you getting a boot screen but no OS Screen? Check your video card and make sure it is in all the way. If on board video, get a cheap video card and try it.
May 26, 2008 | Computers & Internet
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
Unclear fonts and images
Hi
Pls reinstall the drivers for the graphics card and restart the computer and check if it is working.
If it does not work, then download the original drivers from the computer manufacturer or the graphics card manufacturer 's website and install them. Make sure that you have uninstalled the drivers before reinstalling any drivers.
Also pls look for any updates for the graphics card.
Feb 26, 2008 | LG Studioworks 45 14" CRT Monitor
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Samsung SyncMaster 753S 17" CRT Monitor Logo
117 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
