Question about Samsung Digimax S630 Digital Camera
My Samsung s630 digital camera has a totally white screen when turned on. I changed batteries, repeatedly turned on and off, switched modes, but screen still only white. The camera is taking pictures OK, because I can access memory card using usb cable, and pictures are saved. Any help? Thanks.
  • Samsung Master
  • 17,130 Answers
Possible fault with the display unit. The display unit is not processing the video image and could be defective in this circuit.
Since the camera is working fine I would advice that you use the camera fully than to open to tamper. But if you are able to open with the prescribed tools then open to see if there is any loose links or visible faults like connection or dry solderring in the main board. However if the fault is a failure then we need to go back to get the part from Samsung.
Decide on with this advice.
Posted on Aug 25, 2010
My samsung s630 camera takes more time in processing after capturing photo
You can follow these steps below.
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
*******2nd solution
It may require a firmware upgrade. That will involve going to the Samsung website, following links to support/downloads and checking to see if there's an update for your camera.
Apr 30, 2011 | Samsung Digimax S630 Digital Camera
I cannot find a user's manual for Samsung S630 digital camera
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 29, 2011 | Samsung Digimax S630 Digital Camera
My samsung s630 camera takes great pictures, but my flash will not work on any setting i choose please help
Dear Sir,
1.Please put your camera in manual mode or program mode after this select the flash option and then select fill in mode.
2.After this press the shutter button and hold it this will energize the flash and help to take the photo.
3.If these steps do not work then you will have to change the batteries.
Regards, Chandrachur
Nov 02, 2010 | Samsung Digimax S630 Digital Camera
The view screan on my Samsung S630 camera is all blurry
Hi Guys
Every time I'd try to turn my camera on, it would give three beeps and then go off.
I decided to search your Fixya tips, and I found it. All I needed to do was press and Hold the OK/Menu button while I turned on my Samsung S630 camera and it worked!!!!!!
Thanks for the tip, and I hope Someone else will get the same benefit
Elizabeth Flood
The view screan on my Samsung S630 camera is all white looking and blurry! The photos that I take look the same.
Any tips will be most appreciated.
Elizabeth Flood
Dec 04, 2009 | Samsung Digimax S630 Digital Camera
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Fun mode and batteries
Dont use Ni-cd batteries, only NiMH or the new "Oxy" batteries from Panasonic, 5X the power of Alkaline and higher voltage, GREAT disposable battery for a Digi-cam. Some cams will NOT work on the old zinc batteries, even brand new. Fun mode is probably just to edit anyway, probably not a shooting mode.
Feb 25, 2008 | Samsung Digimax S630 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Mode dial on samsung camera
You just have to turn it (not sure if its clockwise or counter clockwise).
Nov 24, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
97 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
