Question about Ots 14D1GX390 14D1(GX390) PPO 4" GR Trash Pump with 130 HP Honda Engin
My honda GX390 runs well but there is no power out put, I checked for burnt wires on the armature and rotor but didn't find any, I cleaned it well and put back but there still no power out put. I am wondering what the problem could be. please can you help.
    Scholar:
  • 97 Answers
What is the gen ser# the number you supplied is for the engine only i can review my books and send you a wiring diagram to trace
Posted on Aug 31, 2010
Calve gap on a Honda GX390 engine? Hi, I have a gas power washer with a Honda GX390 engine in it. I need to adjust the valves. Any idea what the gaps are supposed to be? Also do I adjust on a cold engine...
Hi intake is 0.15+ or - 0.02mm and exhaust is 0.20 + or- 0.02mm cold engine..I always double check after running the engine again...you can check out the owners and service manual and all specs here http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z5F602.pdf
Feb 23, 2015 | Honda Garden
GX390 runs and shuts off
have you checked the engine oil. most models have an oil motion pick up. they are fitted to most lawn mowers as well when the oil gets week it does not lift and engine will just cut out. replace oil with 20/50 oil.
Sep 12, 2013 | 13 HP Engine GX390 OHV Horizontal Shaft
13 HP Engine GX390 OHV Horizontal Shaft. runs perfectly fine/pressure fine for 2 to 3 minutes then shuts off. Have to restart over and over and over. Checked oil, no smoke, took air filter off, cleaned...
Check that the fuel tank is not creating a vacuum. this will starve the engine. After it shuts down the vacuum dissipates and lets the fuel run into the carb again.
Sep 10, 2013 | 13 HP Engine GX390 OHV Horizontal Shaft
Honda gx390 has low power.
Well it sounds like you may need new piston rings or an engine rebuild due to low compression. But a good way to tell if you need an engine rebuild is to test the compression and see if it is up to spec. You can often just feel that the engine is very easy to turn over which is a good sign that you need a rebuild.
May 08, 2012 | Honda Garden
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
Honda EV 6010 generator, no pilot light. I am in need of the ohm resistance on the rotor and stator assy. Any help would be great.
Check for burnt stator, if that ok dismantle the generator end, remove the rotor and fully clean the rotor rings.
Mar 01, 2011 | Honda Electrical Supplies
How to rebuild a 84 honda magna vf 700 starter
The only thing you can do is replace the brushes. Honda only sells the complete starter or just the brushes. The plate set and post set of brushes will run $50-$60. Clean the armature contacts with fine grit sandpaper( flat shiny copper). Make sure you only have continuity between every other contact on the armature . If side by side contacts have continuity , buy a new starter(or good used). If any of the magnet coils are burnt or shorted, buy a new starter.
Sep 10, 2010 | Honda V-Twin Magna Motorcycles
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Apr 07, 2009 | Electrical Supplies
Fuel ,fire,new cap &rotor,wire firin noted ok. still no start.
did you put REAL HONDA parts or aftermarket parts.....i bet you put aftermarket parts in it...Hondas and Toyotas are very sensitive about ignition parts...ONLY get the real deal....NO aftermarket junk. i did the same mistake with my 89 honda accord. never again...
Mar 21, 2009 | 1993 Honda Accord
Ots 14D1GX390  14D1(GX390) PPO 4" GR Trash Pump with 130 HP Honda Engin Logo
230 people viewed this question
Top Ots Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ots Garden Expert? Answer questions, earn points and help others
