Question about Fedders AEP09D2B Portable Dual Hose Heat/Cool Room Air Conditioner w/ 9,000 Cooling BTUs & Dehumidif...
Can i get wiring diagram of a simple cold room
I need to install a car alarm into my 1998 mazda metro and need the wiring diagram for the wires under the steering wheel.
Most aftermarket car alarm manufacturers have support diagrams on their website to assist in identifying the correct wires to install their device. Be advised, if you are not very skilled at electrical installations (and installing a simple car radio don't count), you may be biting off more than you can chew. There is potential for serious damage and/or injury with the wiring under the dash as much of it runs high current. Short something out or connect to the wrong wire(s) and you might be out of a car. I personally have a fair amount of skill in electronics and wiring systems. I have installed five remote start/alarm systems and never had one that I could say went easy. Either the wires are hard to find/access, or there is virtually no room under the dash for the associated electronics that go with the install. Be prepared for a project that can last days.
Aug 31, 2016 | Mazda Cars & Trucks
Replace remote with simple flat toggle remote
May be able to get one from Home meridian........
May 12, 2013 | Home Meridian Comfort Lift Recliner
22 room wire diagram
I would just copy the wire diagram from room 20...
I am sorry but I do not know what Car you are working on, what Make/Model/YEAR.. and can you give me more information please?
Apr 15, 2013 | Cars & Trucks
Looking for wiring schematic for Fender Squier Mini-Player Childrens Beginner Electric Guitar w/built-in amplifier - Black cant find anywhere! not even on Fender site. seems like a simple loose wire, but...
All Strats are wired in similar fashion. There are lots of straight-forward wiring diagrams in the Internet. Seymour Duncan's site has easy to read and understand wiring diagrams for just about any electric guitar. If you open it up buy removing the pickguard, any loose wire reveals itself right away; just check the connections and the solder joints. A "cold" joint looks okay but doesn't transfer current. If it's been worked on previously, that may be the problem.
Aug 10, 2011 | Fender Squier Mini-Player Childrens...
Blowing cold air is there a pilot to light
No pilot on this model. If the room air blower is constantly running it is telling you that there is an error code stored on the circuit board. Look for a small viewing port in the lower section of the furnace. Look in it for a flashing light. Count the number of blinks. Now remove the front panel and on the reverse side there will be a wiring diagram. Also on the wiring diagram there will be a Diagnostic Chart that will explain the blinks. If you remove the panel that opens the door safety switch, it will cut power to the unit and erase the code so find the viewing port first.
Jan 22, 2011 | Goodman GMS90703BXA Heater
Compressor keeps kicking off. When it stays on the air is super cold but obviously once it kicks off i lose the cold air. I am pretty handy just don't know what I should be checking
Allot of times it is a simple fix. If you remove the front cover you should see the thermostat sensing probe attached to the front coil. This is supposed to sense the air intake air only. Sometimes for whatever reason some of the cold output air is directed across this your unit thinks it is colder in the room than it is. It looks like a copper wire attached to the front coil. Sometimes you can simply relocate this towards the bottom of the front coil and it will solve the problem. It should not actually be touching the coil fins but have holders that hold it away from the coil. I have actually just let the end of it stick out under the front cover a little so it will actually sense room air temperature and it has worked well. If you have anything blocking the cold air output like a curtain etc. It will cause your cold air to **** back into the unit and shut it off also.
Jun 30, 2010 | Frigidaire FAC126P1 wall/window Air...
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
I'd like to move the tv to the other side of the room...can you tell me how (make it simple, please) and exactly what I'd need to do the job?
You need a Power socket near the TV, you will need to extend or move the Antenna coax cable. Draw a connection diagram of all connections and mark with them with small stick on labels, label all wires and connections. Then move the TV and connect up as per your diagram. It will be easy.
Feb 24, 2010 | Monster Cable DS500-CL-EZ1000 Dataspeed...
Downlighter wiring diagram
I strongly encourage you to contact a licensed electrician for this work. No offense intended, mate...Electrical work is the one thing I would strongly discourage the average homeowner from doing. Unless you know EXACTLY what you're doing, its too easy to make a simple mistake that could injure or kill you and/or your family.
Last time I worked on an electrical system in Europe, it was because a homeowner (improperly) wired new lights into the place I lived that nearly burnt the place down. All of the fixtures had charred wood under them and the insulation had burnt off of the mains.
Apr 05, 2009 | Electrical Supplies
Fedders AEP09D2B Portable Dual Hose Heat/Cool Room Air Conditioner w/ 9,000 Cooling BTUs & Dehumidif... Logo
314 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
