Question about Toshiba TEC B-SX4 Thermal Label Printer
Ts an sx4t version 5.1 and it comes up with a error message - d042010000390.
    Champion:
  • 254 Answers
This is a syntax error
Normally you should send
{D0420,1000,0390'} for paper size
Posted on Aug 24, 2011
Ts l633 firmware
If you have errors on drive you can use this KB:
like error 19 etc.
http://support.microsoft.com/kb/314060/en-us
IF CD/DVD burn issues, try another software such as Infrarecorder , nero, etc
Dec 15, 2013 | Toshiba Computers & Internet
What is the best software to use for the Toshiba BSX4T Printer : with LAN card ? jack boychuk
Use seagull dirver and bartender. A light version is delivered with each printer
Aug 25, 2011 | Toshiba TEC B SX4T Printer
Fatal error d3d9.dill comes when i start skype what to do
install skype version 4... version 5 has this problem...
Mar 16, 2011 | Skype IM
Error code D042010000390
syntax error
The data should be {D0420,01000,0390'} for a lbel having a with of 100 mm and a height of 39mm with a gap between the label of 3 mm
Aug 25, 2010 | Toshiba TEC B SX4T Printer
How to configure internal LAN in B-SX4T barcode printer?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
May 05, 2010 | Toshiba TEC B SX4T Printer
Hello, How can we revoke Temporary TS per Device CALS in Windows server 2008? Thanks.
hi there,
When a terminal server is configured to use Per Device licensing mode, and a client computer or device connects to a terminal server for the first time, the client computer or device is issued a temporary license by default. When a client computer or device connects to a terminal server for the second time, if the Terminal Services license server is activated and enough TS Per Device CALs are available, the license server issues the client computer or device a permanent TS Per Device CAL. If the license server is not activated or does not have any TS Per Device CALs available, the device will continue to use the temporary license. The temporary license is valid for 90 days. A permanent TS Per Device CAL issued by a license server is configured to automatically expire after a random period between 52 and 89 days, at which time the TS Per Device CAL will return to the pool of available TS Per Device CALs on the license server.
In some circumstances, you might want or need to return a TS Per Device CAL that has been issued back to the available pool on the license server before the automatic expiration period has been reached. For example, you might want to do this if the client computer or device is no longer a part of your environment.
In Windows Server 2008 you can revoke a TS Per Device CAL by using the TS Licensing Manager tool.
In Windows Server 2008 you can only revoke a TS Per Device CAL. You cannot revoke a TS Per User CAL.
After you have revoked the TS Per Device CAL, that TS Per Device CAL will be immediately available to be issued to another client computer or device. Revocation is not a substitute for ensuring that you have enough TS Per Device CALs to support your environment.
You can only revoke up to twenty percent of the number of TS Per Device CALs of a particular version installed on your license server. For example, if there are 100 Windows Server 2003 TS Per Device CALs installed on the license server, you can only have 20 of those Windows Server 2003 TS Per Device CALs revoked at any given time. If you also have 200 Windows Server 2008 TS Per Device CALs installed on the license server, you can revoke up to 40 of those Windows Server 2008 TS Per Device CALs in addition to the Windows Server 2003 TS Per Device CALs that you have revoked.
Use the following procedure to revoke a TS Per Device CAL by using TS Licensing Manager.
Membership in the Administrators group, or equivalent, is the minimum required to complete this procedure. Review details about using the appropriate accounts and group memberships at http://go.microsoft.com/fwlink/?LinkId=83477.
To revoke a TS Per Device CAL by using TS Licensing Manager
1. Click Start, point to Administrative Tools, point to Terminal Services, and then click TS Licensing Manager.
2. Expand the node that represents the license server that issued the TS Per Device CAL, and then select the node that represents the version of TS Per Device CAL that was issued. For example, click Windows Server 2008 - Installed TS Per Device CALs.
3. From the list of issued TS Per Device CALs, select the TS Per Device CAL that you want to revoke.
4. On the Action menu, click Revoke TS CAL.
5. To confirm that you want to revoke this TS Per Device CAL, click Yes.
6. If the revocation was successful, a message will appear confirming that the TS Per Device CAL was revoked and telling you how many more TS Per Device CALs of that version you can still revoke.
7. Click OK to close this message. The Status column for the TS Per Device CAL will show a status of Revoked when the TS Licensing Manager display is refreshed.
Hope this helps, good luck, God bless
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
Dec 04, 2009 | Office Equipment & Supplies
Cannot find License Server
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Oct 16, 2008 | Sibelius Computers & Internet
Toshiba TEC B-SX4 Thermal Label Printer Logo
61 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
