Question about E-Machines eMachines Desktop PC
RESTORE DISC I have an Emachines Desktop. I am trying to do restore cd. Monitor does not seem to have a problem as it is running a test screen but nothing is coming up when I insert CD.
  • Anonymous Jan 03, 2009
    My E: Drive is not responding when I put MUSIC CD IN THE DRIVE
  • E-Machines Master
  • 5,568 Answers
The 'test screen' of the monitor means only that the monitor would display if it receives an input signal.
Make sure it isn't something simple like dislodged video connector on the back of your system box.
You may even want to removed the plug and reinsert it several times in case a sync signal contact hasn't taken a hike.
If this doesn't help, your restore CD won't help either; it means that the video signal (there are several: Red, Green, Blue plus two synchronization signals) is incomplete or missing altogether.
If the video connector is attached to the strip with many others, then the video is on the main board (common on lower end systems) and the chip supplying video has failed.
This doesn't make the system worthless as you can buy dozens of different video cards to plug in to the main board and disable the on-board chip.
I don't know how old your system is but you will likely need a PCI video card (check your manual for the types of buss available for 'add-on' cards) to install and then possibly new drivers from a supplied CD.
This is a pretty simple procedure and even the Chinglish instructions are normally enough to guide you.
Until you can see your system's boot sequence appearing on screen again, you won't be able to restore anything.
Posted on May 05, 2008
File 5391ada02 can't be found....monitor is black
Pick up a second hand monitor, test your system to see if a signal comes through i.e. you have image on screen. before you do a recovery, perform a back up and restore, to a previous date & time. You may just have a bad monitor.
Oct 09, 2015 | eMachines Computers & Internet
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
How do you restore a emachines el1200 desk top to factory settings
[1]
reinstalling the operating system If you can run Windows...1 Click (Start), All Programs, eMachines, then click eMachines Recovery Management. eMachines Recovery Management opens. 2 Click the Restore tab, then click Restore system to factory default. The Confirm Restoration dialog box opens. 3 Follow the on-screen instructions to finish.
[2]
If you cannot run Windows...1 Restart your computer, then press the ALT+F10 keys during startup. 2 Follow the on-screen instructions to finish. IMPORTANT • • If your hard drive has failed and you can't restore the software from the hard drive or recovery discs, contact eMachines Customer Care for help. After you restore your computer, it will appear with the same files and programs it had when it shipped from the factory. You still need to download Windows updates and antivirus updates to bring your computer's software up to date.
Aug 27, 2011 | E-Machines eMachines Desktop PC
The pc won't burn cd's seems like it doesn't recognize cds or dvds
Does the cd/dvd drive read cds? This is a good test to ensure that the drive is functional.
Sometimes, generic cd/dvd burners do not recognize certain types of blank discs. Try another type of
brand blank discs, it should work.
May 01, 2011 | E-Machines eMachines Desktop PC
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    Restore factory settings
    Do you have the windows install disc.If so place it in your cd or dvd drive.Reboot pc.
    Follow on screen instructions for reinstalling windows being sure to format your hard drive.You will loose everything.
    Try a trial version of panda antivirus first, run a full scan.
    Note.. some e machines are not sold with a disc,there is a system restore option on some e machines.
    Jan 14, 2010 | eMachines ET1810-01 PC Desktop
    Have a problem with my machine T3092. The monitor
    Stop using the restore disc, try installing the OS instead and make sure you have your driver software
    Dec 18, 2009 | E-Machines eMachines Desktop PC
    Pc keeps trying to start up but states it needs to reboot and won't. I have tried to insert the operation disc and it does not work either
    it probably says insert suitable boot device. If you are trying to boot from a cd go into the bios and set the boot device priority to CD as priority. If hard drive then set hard disk to the top.
    Apr 12, 2009 | eMachines T5048 PC Desktop
    Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
    Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
    Rate me if this helped.
    May 29, 2008 | E-Machines eMachines Desktop PC
    E-Machines eMachines Desktop PC Logo
    66 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
