Question about Tecnik TKL9290 Front Load Washer / Dryer
Drier does not heat, just cold air so I think I need a new thermostat. Could you tell me where I can get one and who makes it?
  • 176 Answers
In D&L stor
Posted on Aug 25, 2010
I have a TDC6 drier. It starts drying and dryer light is on, but light goes out and it stops drying? Will you be able to tell me what the problem is?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Electric dryer no start does nothing
Oct 10, 2014 | Dryers
Sebring thermostat
I vaguely recall a bleeder on the intake or close to the top? Trapped air will make it overheat again.
Apr 02, 2014 | 2002 Chrysler Sebring
I am having problem with the A/C on my 2000 BMW 323i. I just Changed the Compressor, Drier, Expansion valve. In march I changed all the lines high/low pressure lines and also changed the Drier as well....
The pressure sw. on the dryer maybe weak but the way you explain it I think the sys is low on Freon. The reason for this is you said it did not get that cold. I would add a half can or one to the sys and see if the compressor cycles longer. Hope this helps.
Apr 26, 2017 | 2000 BMW 3 Series
This indesit reverse action dryer (1S31V) has stopped blowing out hot air. I took the back off and cleaned the fluff which had clearly caused the problem. Is there a thermostat or fuse that I need to...
Hi. I have a Hotpoint tumble condensing drier which had the same problem. The solution for me was to access the heating element at the back which involved taking the back off and locating the small metal thermostat which is the size of a two pence coin and 10mm thick.There
is a small hole in the centre and all I had to do was press a fairly thick needle into the hole until there was a click which reset the
thermostat and everything was working fine. This problem does still occur now and again. By the way the heating element is attached
to the removed back with cables giving a clue which helped me find
the unit. Hope this helps Regards Peter
Feb 11, 2013 | Dryers
The dryer is blowing cold air, no heat.
Find your thermal protection switch. It looks like a big round button with two screws holding it on either side. (Make sure your drier is unplugged!) There will be a wire going from it to the heating element. It is what regulates the temperature, so it doesn't overheat. Unplug the wires off it and check across the terminals with an ohm meter. It should have full continuity. If not, it's your problem. Replace it. Easy repair.
Feb 18, 2011 | Hotpoint Aquarius WD63 Front Load...
Have 3 ton elec a/c and heat - heat is on and air is blowing cold, unit is new (15 mos) home 1350 sf - breakers are OK, filter is clean - what can you tell me?
If its not a heat pump- check the white wire connection on the thermostat. If it IS a heat pump, check the blue wire connection on the thermostat. Both of these wires control the heat in their respective systems.
Jan 26, 2011 | Ruud UAMB042 Air Conditioner
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
VW jetta over heating after new thermostat installed
there could be an air gap in you coolant circuit, make sure you have purged the entire cooling system of air that might have been be trapped in the cooling circuit when you changed the T-stat.
Dec 30, 2008 | 2001 Volkswagen Jetta TDI
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Washing Machines Logo
29 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
