Question about Fellowes P50CM Shredder
Good morning-my P50CM shredder motor seems to be working fine (same noise as usual) in both forward and reverse, however it wont accept paperfor shredding .I have removed as much cut paper between the shredding blades as possible but still wont work. Any ideas what we can do ? thanks
  • Anonymous Mar 17, 2014
    cutting blades rotate on reverse. I need to hold the forwardbutton to start shredding
  • 86 Answers
You shredder needs a new shredding head. I'm sorry to say. You will be better off getting a new shredder. I am a senior level shredder technician in CO. I have seen this problem many times and it is an expensive repair. Hope this helps. If you have further questions please respond.
Posted on Sep 03, 2010
My shredder says it will shred cd's and dvd's but when I tried, a cd went in 1/2 way and now is stuck. Motor runs but nothing happens in forward or reverse
You can turn the shredder over (after unplugging the power cord) and see if you can pull the pieces out from under side.
Sometimes the motor gear teeth break off, and the motor just spins but wont go forward or reverse.
Hope this helps.
Feb 25, 2015 | Shredder Office Equipment & Supplies
My ativa hs 2000 paper shredder will only run in reverse
If the motor will only run in reverse and, you are stating that all the buttons are working. then most likely, internally the motor has burned out try tapping the motor lightly with a small hammer while the shredder is plugged in and on in the forward position. if the motor begins to move it will lead you to the answer of a shorted out internally motor.
Oct 15, 2012 | Office Equipment & Supplies
Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Sep 13, 2012 | Staples ID Armor SH2836ID2836 Shredder
Infoguard-10 sx100m motor runs, sounds like gears are turning , goes both forward and reverse. i cleaned all of the teeth, looks clean, but won't accept paper. i am handicapped and am having a hard time...
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck...
Apr 15, 2011 | Cross Infoguard Shredder SX102M
Our shredder motor is working but it will not go forward to shred. It will reverse. I've unjammed every visible paper jam but still nothing. HELP!
If it wont run forward but does run in reverse you may have lost the PCB inside.... contact Royal at 1-800-524-0799 for parts assistance and pricing.
Nov 29, 2010 | Royal CIA 12X Shredder
Switcheson fine but does not accept paper
Does it run in reverse???? Does the motor work.???
If it runs in reverse then the motor is probaly OK....does your machine have "eyes" that automatically start the shredder when the paper is inserted??? if it does then they may be "dirty/dusty"...try cleaning them ; if that dosn't fix it then you may have defective "eyes" or defective pcb.
May 10, 2010 | Office Equipment & Supplies
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
May 03, 2010 | Fellowes Office Equipment & Supplies
Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Oct 25, 2007 | Fellowes P600C-2 Shredder
Fellowes P50CM Shredder Logo
583 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
