Question about RCA P52955 52" Rear Projection Television
My tv sounds like it wants to come on it just keeps making the sound like its coming on.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U may have a problem with the high voltage power supply (flyback tansformer )
Posted on Aug 25, 2010
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
My sound is not working. I have a picture but no sound
Hello
Pictrue being Ok and there is no sound is your problem. It may be either fault to its speaker or it sound output Ic. You can be sure about which of this has got troubled by yourself. Keep your ear very close to the speaker side of your TV, and switch it "ON" bu "MAINS", not by remote control. If you can hear a "Thumb" sound or a "Hum" sound, you can make sure that your TVs speaker is OK. If there is no sound at al, it means that there is some fault to your TVs speaker. It can be due to a socket trouble also. If there is an earphone socket in front panel of your TV, just insert an earphone pin into it and check whether sound coming from it or not. If there is sound through earphone, and when it is unpluged, sound does not transfer to the speaker, means that socket has some trouble. Replacing it will solve the problem.
If you hear a "HUM" sound, as decribed earlier here, this may due to the Sound Output Ic inside the circuit borard of your TV. To rectify this fault, ypu have to open your tv, and locate the sound output ic. Just follow the speaker wire, and somewhere near it orginates from the mainboard, or other board, can locate it. Usually this IC will be screwed into a metal plate, inorder to radiate heat from it while working. Check for any loose solderings to its legs, that may also cause it to be nonfunctional. Anyway resolder its legs first by applying a little more solder, and check the result. If this also doesn't help, resolder it out from the board, and go for a same type and number. Replaceing it will solve the problem. Ok.
Take every precautions before you open your TV. Keep children away from you while you are working. Never allow to them even stand beside you, and allow an adult beside you as a pracationary measure, and as a helping hand. Keep AC power chord out of wall socket each time you make contact with the inner circuit board of your TV.
If you wants any further assistance, inform me through Fixya.
Nov 08, 2010 | Samsung TX-R2035 TV
Beautiful picture,no sound
Hello
If your TV displays good picture and there is no sound output from it, please connect an earphone or headphone to its headphone/earphone socket, if provided, and check whether the sound output comes from it or not. If there is sound output from the headphone socket, and not heard from the speaker of your TV, the speaker inside your TV may got damaged. Check the speaker of your TV. For that you have to open the TV. Unscrew it and go for the same type and number and replace it. There is an other possibility, that is if your TVs headphone socket itself can got damged. You can make sure it by after checking your speaker. If the speaker is alright; the socket is faulty. Replace it with same type.
An other fault can occur is Audio Output Ic failure. If it has damaged, you won't get sound output either from speaker or from the headphone socket. You can make sure about it. Keep your ear very close to the speaker side of your TV, switch on the power to TV. If there is a "Thumb" soud is heard, you can make sure that your TVs speaker is Ok, and if there is a "Hum' sound also comes from it, Output Ic is damaged.
If so you have to open your TVs back cover and locate the Audio Output Ic. It can be located by following its speaker wire. The speaker wire goes to Output Ic. Usually it may be screwed into a metal heatsink. Desolder it out of the board, and go for the same type and number. Replacing it will solve the problem.
All the precautions must be taken before opening your TVs back cover. Plug it out from the wall socket bfore doing this. Keep chldren away from you, and not let them even stand beside you. Let an adult be there beside you as a precationary measure.
Read and understand well the above said solutions and go on.
Wish you sucess.
Oct 23, 2010 | RCA 27V514T 27" TV
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
PROSCAN TV
Hi
the ticking sound is coming out from the flyback that is high voltages!!! if you on the unit is there a picture coming out? or sounds coming out from speaker?
Thanks!
Jul 02, 2008 | Televison & Video
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
RCA P52955 52" Rear Projection Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
