Wiring diagram for wiring up lan sockets - Computers & Internet
  • 32,281 Answers
<P>This WEB site shows the wiring of the RJ45 sockets/plugs and the colors for each pin position.</P><P><A rel='nofollow' href="http://www.incentre.net/content/view/75/2/">http://www.incentre.net/content/view/75/2/</A></P>
Posted on Aug 25, 2010
Wiring diagram for 3 way 2 socket lamp
Where is the switch located? If you buy a replacement switch at Home Depot it usually comes with a diagram that shows you how to wire it. If the switch is built into the light socket just replace the socket the switch is included.
Jul 29, 2014 | Leviton Electrical Supplies
Wiring diagram
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
wr426 Wiring diagram Google Search
Wiring Diagram
YAMAHA WR426F Owner Service Manual
OEM parts for Yamaha
YAMAHA WR450F Owner Manual
Feb 13, 2014 | Yamaha WR 426 F Motorcycles
I have a (like) phone chord and can't find where to put the other end. We have it plugged into the back of the router, need to know where to plug the other end.
Hi
It depends on which country you are in.
It depends what Broadband wiring setup you have.
It depends which type of cable you are talking about (see images 1 and 2 below)
In some countries, the RJ11 to RJ11 cable goes from this device into the phone Socket of an ADSL filter. One RJ45 to RJ45 cable goes from the Router into the Ethernet Socket of the ADSL Filter. Another RJ45 to RJ45 cable goes from the Router to the Computer. The ADSL Filter then goes into the Phone socket in the wall.
You need an ADSL Filter in every Phone Socket that has a telecommunications device attached to it (Fax Machines, Answering Machines, TV Set Top Boxes, games Consoles etc.). The ADSL filter separates Telehone, Voice & Fax Data traffic from Broadband traffic and allows all to share the same phone line with out conflict.
See Network Diagram below.
In some countiries or wiring setups, the RJ45 to RJ45 cable form the Router to the Wall does not need to go via the Phone Socket and can go directly into its own dedicated Ethernet Wall Socket.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa
IMAGE 1: RJ11 to RJ11 or ADSL MODEM or BROADBAND or TELECOMS or TELEPHONE Cable
virtual_a_4.jpgIMAGE 2: RJ45 to RJ45 or CAT5E or LAN or ETHERNET Cable
DIAGRAM 1: Typical UK Home Broadband Network Diagram
Aug 30, 2011 | Linksys Wireless-G Broadband Router
Need wiring diagram for front panel
Take a look here:
For more info, download the manual...
Best regards,
Pelu.
Feb 18, 2011 | Fujitsu Siemens D2030 SiS 761GX Socket 939...
I need to get diagram for hooking up my motherboard
Hi Ram,
Thank you for contacting Fixya. This is Anil.
I understand that you need a diagram for Intel D915GAG Socket 775 Motherboard. I will be glad to help you with it.
Ram, please visit the below mentioned link to download the manual of the Motheboard
http://downloadmirror.intel.com/15197/eng/D915GAV_D915GAG_TechProdSpec.pdf
Under this link Click on 1. Product Description> 1.3 Overview> 1.3.3 Board Layouts, you will get the detailed diagram of the Motherboard.
I believe the above resolution should resolve the issue, however, if you need anymore assistance, please feel free to contact us. We will be glad to help you.
Thank you. Have a Great Day.
Regards,
Anil.B.R
Jul 18, 2010 | Intel D915GAG Socket 775 Motherboard -...
Replace old tv antenna with a new one.
make diagram on paper of the old socket . Carefully unscrewing old socket from wall, DO NOT CUT WIRES, copy color of wires (if any) and where and how meny wires on the paper. EXAMPLE:: you have just pulled old socket away from wall, look and see how meny wires, colors if any, and where they are in contrast to the socket.(left wire=blue, middle wire=black, left=yellow, connector that is up or down=color. MARK these wires on paper, and if possible TAPE a piece of paper with a nember[#] on the wire and place that # on the paper corresponding to the wire in socket wall.
Take the socket to electronics store.NOTE;; IF STORE does not have a exact replacement ask store for SIMULOR replacement.Show the diagram you made to help you buy the right replacement.
Good luck
May 05, 2008 | Televison & Video
Motherboard wiring diagram
i need a wiring diagram of my mother board...usb power etc etc. any idea where i wud find this
regards Des
Feb 07, 2008 | Intel Motherboard
Install
for what front coneters to mobo for power rest ect ?>
Jan 19, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
