Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment cooling fan. I unplug the refrigerator for a few moments and then replug it and the panel lights up again and I can get water dispensed. However, after a while, the panel goes back to displaying the error message Er 1F and I can't even get water to dispense. Can you assist? Is this some kind of circuit problem or do I need a new fan?
  • Anonymous Mar 18, 2014
    Error Er 1F
  • 15,935 Answers
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
May 26, 2017 | Kenmore Refrigerators
Error code er 1f
Check all wiring behind fascia and freezer door hinge
Apr 13, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Managemylife
That error comes from a failing fan due to ice build up which directly affects your ice maker.
Feb 26, 2014 | Kenmore Refrigerators
H20 dispenser displays er lf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MY ICE MAKER WON'T WORK
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,864 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
