Question about Goldstar Televison & Video
I have a goldstar tv Model no. CF29C36T. I want to connect to cable, need to know what kind of adapter to get for coaxial cable and where can i get it?
SOURCE: Coaxial to component
Get a VCR and use the VCR as a "bridge" between the cable input and the TV. Your TV should have generic RCA jacks that will accept the output from the VCR.
Posted on May 27, 2008
Bhatcher5127
  • 6 Answers
SOURCE: connect to coaxial cable in wall
You have BNC connections on your TV you need a BNC to Coax adapter sold at any AV store and sometimes radioshack.
Posted on Sep 09, 2008
  • 48 Answers
SOURCE: connect magnavox dvd to ge tv HELP!
There are a few options to connect an older t.v. with a DVD player.
  1. You can connect your new DVD player to a VCR....not recommended as quality loss will occur....use RCA plugs (Red/white/yellow) but it is easy...and many people have an extra one around
  2. plug one end of RCA cord into DVD player, other end to VCR (colour match red plug to red cord)
  3. then to connect VCR to TV...use the coax VIDEO OUT (on VCR) to the TV
  4. OR you can purchase an RF modulator like this at http://www.amazon.com/exec/obidos/tg/stores/detail/-/electronics/B00009MDBN#moreAboutThisProduct
  5. this option has a greater cost...but the picture quality will not suffer....Note..you will not have Surround sound...but as it is an older tv. you were not used to that anyway..
Great way to keep an older working t.v. out of the landfill
hope this helps!
Posted on Oct 09, 2008
drumbanger
  • 1199 Answers
SOURCE: speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Posted on Dec 28, 2008
  • 71 Answers
SOURCE: Hook cable box to this receiver
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
Let me know if I clearify any of this.
Posted on Jan 02, 2009
I have a RCA digital amplified indoor/outdoor antenna. I need an adapter to connect the coaxial cable from the antenna to the input on the TV.
Robert, Radioshack/The source any type store like this has the adapter you want. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Attach Coax Plug To TV Aerial Cable
Coaxial Cable Connectors Walmart com
TV Antenna Adapter eBay
Aug 27, 2016 | Envizen Digital Quartet 9 Ed8890a Portable...
Replacing coaxial input
Coaxial cables are all standard for that kind of TV. I'm about 99% sure on that so just go to a electronics shop and buy one and double check with the person at the shop but I'm sure you'll be save just replacing your old one with the same size!!!!
May 10, 2015 | LG 50PV450 50 in. HD-Ready Plasma TV
I moved the Mintek Tv from my bedroom to the living room, the tv cable cord will not screw into the Tv, I was told that I need a adapter, coax to av-rca, is this correct? What do you think?
Not sure due to lack of information to go on
I. think you need a tv coaxial female to f plug male adapter
really depends on the TV cable cord what is the gender of the end of the cable if it is coaxial male then the adapter needs a female coxial
if the tv has a female socket hole then the f type part of adapter needs to be a male.
The tv manual may shed some more info on the type of RF antenna coaxial connector. it uses.
RCA can be confused as av is to do with with hooking up a Video recorder with Video output being the yellow plug and audio with Red and white plugs.
http://www.4cabling.com.au/rca-audio-and-video-cable-10m.html?gclid=COyD3pvqpsUCFYqCvQodP38A1Q#.VUa9JZM_xhI
I think you need a RF coaxial adapter rather than AV RCA if you are connecting tv to a tv antenna or tv antenna splitter device.
there is a RCA standard that has adapter like below link http://www.radioparts.com.au/product/30255099/pa5099-%27f%27-plug-to-rca-socket-adaptor#.VUa7uJM_xhI
again gender types are needed to be considered before deciding if correct type of adapter..
You could research the rca rf standard to see if it is used in your country. My country uses Pal coaxial standard.
http://www.ebay.com.au/itm/like/271684688400?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=107&chn=ps
May 03, 2015 | Mintek Televison & Video
CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
Connections
You need a coaxial cable with an RF modulator. Better yet, there are several ORIGINAL Atari 7800 RF consoles for sale on eBay for $4 to $5 a pop. Have fun!
Oct 10, 2008 | Atari 7800 Console
Connect to coaxial cable in wall
Sep 09, 2008 | Panasonic TH-42PWD3 42 in. Television
Connecting Dell speaker system to TV or console
If you have a coaxial out on your TV and a coaxial in on your Speaker system that is the way to go to experience digital surround sound. Radio Shack, etc. has coaxial cables in the appropriate size. If you go to Radio Shack, etc. bring along your speaker system's model number as well as your TV's model number.
Hope this gets you going.
Worldvet
May 18, 2008 | Audio Players & Recorders
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Cable in connection
Most TV models/cable providers uses the F type of coaxial connector as shown below. 7c21c7e.jpg
However, some versions intended for other regions (Europe & Middle East) uses the PAL type of connector likewise shown below.
If your model uses the latter and your cable provider uses the F type, what you need is a straight F type Female to PAL Male adapter. Or it could even be just the other way around.
They are available in most electronic parts/supply store or online. You can try here, here or here.
Hope that this be of idea/help. Pls post back how things turned up, r should you need additional information and/or if your cable connectors are of different types. A photo of the connectors would be nice.
Good luck and kind regards.
Jan 06, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
43 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
