Question about Brookstone Personal Ionic Air Purifier Air Purifier
Unit makes a clicking noise like it is shorting somewhere tried blowing air through it but clicking noise comes back no dust have you any outlets anywhere in australia sydney
  • 19,396 Answers
Hi.
The unit is not manufactured anymore.
There are several health concerns on air purifiers. The bigger Ion-Breeze line and similar products had been retired from the market for the same reason.See:Ionic Purifiers concern
and Dangers of Ionic Air Purifiers or The Dangers of Ionic Air Purifiers
This unit is not really dangerous, as it is really small, and it is supposed to be used sporadically.
I suggest not repairing the unit, but if you really want to repair or replace it try contacting Brookstone.
Posted on Aug 25, 2010
Brookstone Pure Ion Pro clicking noise, ineffective. I understand the "sparking" is ok, but my unit doesnt "spark". The fans run, and the unit makes two different clicking noises; ...
did you ever figure out the clicking noise problem?
mine stared doing the same darn thing after I whashed the filters and inserted them into the units, I used the builted in drying setting, and thats when the problem started. I know you are not supposed to run the unit with a wet filter, thats why I put it on the dry mode first. I think I am just going to return them back to Brookstone.
Jul 08, 2012 | Air Purifiers
Crackles even after blades are cleaned
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. To do this, approach the unit from the front, and turn the blade door slightly so the wire can be seen. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Oct 19, 2011 | Ionic Pro TURBO Air Purifier
Makes a zapping noise when you turn on the electronic air cleaner
If the the "zapping" noise you hear is intermitant (like a Bug Zapper) it's probably dust that the air cleaner is picking up from the household air. .If that's the case, there's nothing to worry about, it's doing it's job.
If the "zapping" sound is continuous, then the unit may need cleaning, as it may be clogged with dust & lint.
Feb 08, 2011 | Air Purifiers
My unit is going off and coming right back on intermittently while running.
Something is probably loose either inside or in a connection somewhere. Make sure the plug is FIRMLY inserted in the back of the machine. Look inside and make sure that the plate is inserted correctly (in both top and bottom "tracks"). Make sure the metal contact "fingers" are pressing firmly against both sides of the plate. Make sure there are no wires that have pulled loose or corroded out. Also, make sure the machine is not plugged into an outlet which is on a line with a heavy appliance or furnace that draws a lot of power. If none of this helps, contact the company (now called Vollara) at 800-989-2299. You can use 16618 as your dealer referral number if you're no longer in contact with the original dealer.
Jan 31, 2011 | Ecoquest Fresh Air Air Purifier
CLEANED FILTER. PUT THE FILTER BACK IN AND NOW IT IS MAKING A CLICKING NOISE. TOOK THE VACUM TO THE FILTER AND IT IS STILL MAKING THE NOISE
The clicking noise is the sound of the high ionizing voltage 'shorting' due to dirt or humidity or both which provides the pathway for discharge. Cleaning and completely drying the filter(s) does not always help, in this case switching the unit to a lower operational speed can mitigate this problem. New filter(s) may be needed to resolve the clicking.
Sep 13, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Describe your Sharper Image Professional Plus? Ionic Breeze® QUADRA? GP Silent Air Purifier Problem: We cleaned it, now it makes a noise. How long is the warranty? Any idea what the noise is? ...
Warranty on these units expired on the 30th of May, 2008 when the company's assets were acquired and liquidated by Hilco Consumer Capital, Gordan Brothers, and Bluestar Alliance. All warranties became void with the bankrupt status.
With regard to the unit that you cleaned, I am assuming that you cleaned it the usual way you always have and it is now making a statical noise or a vibrating kind of noise, correct?
While the unit is off, take out the insert, pick up the unit and turn it upside down. You will hear some beads moving from the elevated end moving towards the bottom. Turn it upside down again and let the beads move to the bottom again. After doing this a few more times turn it upright and put the insert back in. You just cleaned the static lines. Turn the unit back on and see if the noise is still present. If so, try cleaning the insert again and after drying, see if the noise is still present. It is usually some dirt present somewhere that causes the noise to persist. If you have completed everything and the noise still persists you need a new insert which you can get on ebay.
Jun 30, 2009 | Sharper Image Professional Plus Ionic...
Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Jan 12, 2009 | Oreck XL Professional Air Purifier
No clean air smell/crackling & static
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
Making sizzling noise
Unfortunately Sharper Image has discontinued support on the product line.  There was a recall going on with the product but since the company is chapter 11 right now, I don't think it is being honored right now.
What happened was Consumer Reports ran a test on ionizers, Sharper Image received a bad score and filed a lawsuit.  They lost the suit and had to pay all legal bills.
EPA has reported that using ionizers in a house or business may be harmful to your health.  You can read an article about it on their website.
The Consumer Products Safety Commission is going to release a final report on all ionizers by the end of the year.  Their decision may discontinue all sales of any ionizers in the United States.  This industry should have been regulated years ago just by the EPA data alone and for some reason it has been ignored.
Sep 10, 2008 | Sharper Image Professional Plus Ionic...
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
Brookstone Personal Ionic Air Purifier Air Purifier Logo
77 people viewed this question
Top Brookstone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
