Question about Honda Electrical Supplies
I have a honda generator it generates power but there is no power out put, what could be the problem
    Scholar:
  • 97 Answers
What is the model and ser# so i can check my books
Posted on Aug 31, 2010
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
U How do you fix a Honda generator 1000i engine runs but no power at 120 out let.
if the motor engine is working and no power output then you need to check is there any power out from the generator motor directly (not in the power out put box I hope you already checked in there) generator motor coils could have busted due to over loads. so even the engine is rotating the generator it can't produce any volts.
Jul 31, 2015 | Honda Electrical Supplies
My Honda E X 5.500 ,5.5 KVA GENERATOR will start but not put out any power
Have you checked the output with a VOM, or just plugged in a tool, light etc?
Aug 01, 2014 | Electrical Supplies
Honda eb5000 generator
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
When you give any load to generator it become off, please tell you what you should do?
you are overloading the generator as per its power out put specifications
Jun 14, 2012 | Honda 3000 Watt Portable Generator
When you put a load on generator it powers up and down and tries to cut off.
sounds like you are trying to put too much of a load on your generator. I have a 3500w generator and when I hooked it up to my 120v (not sure how many HP) well pump when the pump would try to cut on the generator would bog down and even die. took off the load and started right up. will run other things just not heavy loads. maybe you need a bigger generator for what you are trying to power.
Oct 28, 2010 | Honda Electrical Supplies
Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
May 28, 2009 | Electrical Supplies
Electrical Supplies Logo
258 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
