Question about Hobart 24 in. LXIC-5 Built-in Dishwasher
LXGH E5 Code
Customer has an LXGH that shuts down on E5. The unit goes through wash normally, switches to rinse, switches back to wash, then shuts down on E5.
The unit fills normally, has 15 PSIG water pressure from the building during fill.
Pulled the drain valve for inspection - nothing. Drain valve cycles normally and does not leak.
Is this actually a fill problem ?
  • capscotech May 12, 2008
    I appreciate the response, but it's a moot point now.
    The customer has had enough problems with this unit, and when I returned to the site the LXGH was nowhere to be seen, and there was a new Jackson unit in place of the LXGH.
    I asked what happened, and the response was "don't worry about that Hobart unit, it's going to the dump. See accounts payable for your check, and thanks for trying.".
    Some folks have short fuses.
    Scholar:
  • 68 Answers
I need to check my codes to be positive. And I'll check them this weekend. But, I believe E5 is from excess water in the unit, and so it won't go into rinse and add more water.
First and most common -- the drain hose, at the back of the unit is kinked. The unit gets pushed back against the wall and kinks the line.
Second, your probes are dirty. The ones in the back right corner detect water level. Clean them with a green scrungee even if they look clean.
Good luck - Mike
Posted on May 10, 2008
My tcl split ac works for 5 min, then gives e5 code.
E5 s a communication error between the indoor and outdoor units. It is stated in the service manual that the wiring between the indoor and outdoor has probably separated at one end of the terminal block. Most of the time however, it is usually a failure of either the indoor or outdoor electronic boards. A multimeter and knowledge of how to read "communications voltages is required. The machine will continually assess itself electronically to make sure all components are working properly. If after a given amount of attempts to communicate with the outdoor unit the machine still cant "talk" to the other 1/2 , it will show an E5 error and shut itself down. You could try switching off the power at the isolator or meter box for at LEAST 15 minutes and then turn back on to see if it resets. This sometimes works. Do not, just switch off and switch straight back on again.
Mar 24, 2015 | Heating & Cooling
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Unit will not switch from hot to cold
check hoses connections- hot to hot and cold to cold at both ends. If not ok, check if you are setting the machine correctly. These days washing in cold water is effective.
Dec 08, 2013 | LG WM2101H Front Load Washer
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
My Neptune is shutting down with a SUDS error
If machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
Unit shuts off, getting an E5 error. sounds like there is a lot of water inside. the customer service numbers for Windchaser are disconnected. PLEASE HELP!!!!
E5 is the fault code for Compressor overheat/malfunction it coulb be caused by the exhaust hose being too long or kinked, remove the exhaust hose and run the unit for an hour and see if your problem goes away, if so re-route the exhaust hose, if not you need to contact the manufacture
Jul 22, 2011 | Windchaser PACR10 Portable Air Conditioner
Whirlpool washing machine will wash but will stop and not drain or rinse
Hi!!
In order for the high speed spinning (rinse) cycle to begin, the lid must be shut. If your unit is top load, the problem is more likely the lid switch. or the tab on the lid that activates the switch is broken. If the tab is OK, disconnect unit from power outlet, remove back panel and trace the two wires going to the switch, once located, use a piece of wire to jump the two together, reconnect unit to power outlet and set the knob to rinse cycle, if unit works, replace switch.
Good Luck!!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 16, 2011 | Whirlpool Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Hobart 24 in. LXIC-5 Built-in Dishwasher Logo
805 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
