Question about Kenmore 66862 Dryer
My dryer wont heat up - Kenmore 66862 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape or with an ohm meter. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Aug 25, 2010
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Gas dryer heats then wont heat?
Bad ignitor most likely. Has a hair line crack, and yields an iffy contact.
Jun 21, 2010 | Maytag MDG2706A Gas Dryer
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
My frigidaire electric dryer wont heat up, only
heatman101
May 11, 2010 | Dryers
Wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
kllk
Aug 03, 2009 | Roper RGX4634KQ Gas Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Kenmore 66862 Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
