Question about Roper Dryers
The fire wont lite liat the bottem of my dryer
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Got wet top screen is flashing and then started the bottem sceen also now it wont start at all
You can try gently using a blow-dryer on it. Electronics are basically useless if exposed to water, but if it was only a small amount, you have a slight chance of getting it to respond with the blow-dryer technique. Wait until ALL of the water is visibly gone before attempting to power it up again. It's worth a shot.
Aug 09, 2011 | Nintendo DSi Black Console
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
My magic chef clothes dryer won't fire up. The ignitor glows about every 30 seconds but no ignition. I checked the gas supply ,made sure it was ON. HELP ME PLEASE!!!
if the ignition is working but wont lite the gas presure valve is detecting a fault and refusing to lite you will need to have it checked by a cert plumber.. sorry
Jun 18, 2010 | Magic Chef CYG3004AWW Gas Dryer
DS lite will not read any DS games. When the DS
Thats normal, there should be a flashing part of writting at the bottem of the screen saying "touch the screen to continue" just touch the screen.
Dec 26, 2009 | Nintendo DS Lite - Onyx
Gas dryer ignites but wont stay lite
Try shorting out the Hi-limit sensor(Lg calls it that, don't know for whirlpool). See if that does anything. If it fixes that, don't leave it like that. replace it and the other fuse by it as well.
Nov 30, 2009 | Whirlpool Dryers
4 wheel drive wont work . lite blinks lite flashes
under the hood ,in the center of the fire wall is the relay that sound bad
Nov 25, 2009 | Chevrolet Blazer Cars & Trucks
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
I have a duet dryer elec. truns on but will not run. when I push the start bottem it just beeps
Usually this means the belt is broken,the belt may have just been old and worn out and it was time to replace it,or perhaps the wheels locked up or the idler and caused the belt to break. Look around for stiff wheels, bad bearings, glides and idlers. Its a good idea to oil the rollers with some temp resistant oil such as zoom oil. Dont use WD40 as this stuff is highly flammable and may cause a fire.
Sep 12, 2009 | Dryers
When i turn on the ds the bottem screen flashes them turns off.
you cant fix this your self there is a mojor common fault
i would buy a new or get it repaired at:
http://www.nintendo.com/consumer/repair/
Jul 23, 2009 | Nintendo DS Lite Console
Gas smell
Fire Hazzard ? YES !! Sounds like the ignitor is taking too long to lite the gas. This lets the gas trickle into the machine. It is very important to the operation that the ignitor lite within 30 seconds on the first try and within 20 seconds thereafter.
Dec 10, 2007 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
